1980 Clutch G Clips
Old 03-12-2019, 07:28 PM
BIGJIM13
CF Senior Member
Default 1980 Clutch G Clips
1980 Clutch G Clips ... are there supposed to be washers on both sides of the linkage before the G clips ... the book shows washes on the transmission side but only shows cligs on the stick side of the linkage ... should there be washers on both ends of the linkage ?
BIGJIM13 is offline
Old 03-13-2019, 06:04 PM
DUB
CF Senior Member
I do not use any washers when I install the 'G' clips on the shifter linkage.....or the clutch linkage on the firewall side. The only place I may use a flat thin washer is the 'G' clip for the clutch push rod where it attaches to the clutch pedal.
Common sense DOES come into play where IF I go to put the 'G' clip in and I can see that the tension on it is not going to be correct...THEN I will add a thin washer. But 99.9999% of the time I do not need to put flat washer on the areas they go.
DUB
DUB is offline
Old 03-14-2019, 05:42 PM
BIGJIM13
CF Senior Member
Thanks - the original assembly book shows them on the linkage on the trans side ... thanks !
BIGJIM13 is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
