First time owner wants a bit more speed
Old 03-16-2019, 07:21 PM
gg521
gg521's Avatar
I am not trying to be a smart *** or wise guy. I have been vintage racing for more years that you have been on this earth. Right now as the car exists it is probably way faster than you are. Learn how to drive the car before you spend a bunch of money, Once you become a bit more proficient, then spend some money.. Having a fast car does not make you a better driver. When I first started the racing thing, one of the "old timers" came up to me and said the same thing to me. He said to not spend a lot of money on the motor right at that that time but maybe on the suspension a bit because " you ain't that fast yet".
Old 03-16-2019, 09:17 PM
7t9l82
7t9l82's Avatar
I don't know how many times it has been written here the N.H.R.A factored the 79 L-82 at 312 horsepower. That would probably require an free breathing exhaust.and a performance tune up. If you can't get your distributor curved and carb jetted and set up you probably won't have everything it's capable of.
The heads are an impediment to performance but it's mostly the chamber is huge.they could be made to breath with some work but that chamber is too big and compression is your friend.as for the L-82 intake, it is garbage cast in aluminum instead of cast iron..why that lightweight boat anchor is so highly regarded boggles the mind.anything you do to that engine will help it alot.
Old 03-17-2019, 01:48 PM
Crimson Thunder
Crimson Thunder's Avatar
The first thing I would do is get a set of 1 5/8 long tube headers and put true dual exhaust on it and get rid of the restrictive factory catalytic converter. Then tune the carb and distributor.
Old 03-17-2019, 05:38 PM
ratflinger
NCM Grand Opening Veteran
Support Corvetteforum!
ratflinger's Avatar
St. Jude Donor '11, '17
So, where did the OP go?
Old 03-17-2019, 06:35 PM
jackson
jackson's Avatar
post # 18
loafing w/ a co-ed
Old 03-21-2019, 12:32 AM
Tslayer66
Tslayer66's Avatar
i agree with this. You will gain a second or more in the 1/4 and one of the 1st things you should do. Then maybe in the future a cam and heads swap.
Take your time and enjoy the car there fun to play with!
Old 03-21-2019, 12:29 PM
Jebbysan
Dr. Detroit
Jebbysan's Avatar
Received 3,892 Likes on 2,564 Posts
Originally Posted by 7t9l82
........as for the L-82 intake, it is garbage cast in aluminum instead of cast iron..why that lightweight boat anchor is so highly regarded boggles the mind.anything you do to that engine will help it alot.
Amen.
Jebby
Old 03-21-2019, 04:44 PM
Khibbs
Khibbs's Avatar
Here's some great info on uncorking the potential of the L82 engine. Pretty much a "top end kit" as others have suggested.
Super Chevy L82 Makover
Old 03-21-2019, 09:28 PM
7t9l82
7t9l82's Avatar
Excellent article, I saw it years ago.it concurs dead on with the N.H.R.A factoring that engine at 312 h.p stunning coincidence.
My only gripe with the article is they didn't do a first test with the heads and intake and no cam change. I saw one set up like that with 1.6 rockers and made 400 h.p and maybe a couple over. The stock L-82 cam is a better all around daily driver cam than the one in the article.
Old 03-22-2019, 03:12 AM
brassplyer
brassplyer's Avatar
Originally Posted by 7T1vette
My advice: Enjoy the car you have.
I would concur with this - making more power takes money and time to devote to working on the car. If you're in college your priority should be to do well in school and get set up for a stable, prosperous life. If you've got a solid runner already that isn't draining your finances count yourself fortunate.
Old 03-22-2019, 06:51 AM
Tom_K
Tom_K's Avatar
OK, If you are taking on student debt for college and trying to build this car, I'm going to kick your lilly-white ***! No Debt!
If not...
Take your time! There is a lot of good advice here. view this as a 5 year project to slowly transform your car.
Keep a close watch on ebay, swap meets, craigslist.... Given time, you can always find deals on anything.
You may find a 350/350HP engine - a complete swap is a viable and sometimes very affordable solution....
My fist car was a 66 Falcon strait 6, (I got it is 1985) over an 8 years I transformed it to a 289-V8, 4-speed hot rod.
...I really miss that car.
But take your time. Oh and do the suspension first! handing trumps HP for fun factor and lots of HP with a poor handling car is bad....
Old 03-22-2019, 11:02 AM
OldCarBum
OldCarBum's Avatar
Received 4,690 Likes on 2,933 Posts
I've been driving my 73 for over two years while collecting parts for a body off resto/mod.
It takes time and every time I get a new part I'm that much closer.
Quick Reply: First time owner wants a bit more speed
