76 Corvette no start. Turn key nothing happens.
Hello friends. So I've recently had some troubles getting my Corvette starting. I live in MN and only start my Corvette once a month or so, to keep it from sitting to still
Recently I went to try to start, and nothing happens. And I literally mean nothing. Purchased a brand new battery, and still nothing. When I turn the key it slides effortlessly. No clicks, or resistance what so ever. Slides from lock to start in one motion with no clicks in between. No lights, no radio, no fuel pump starting, complete silence
Just replaced the ignition lock cylinder thinking that might be the culprit, but the same thing is happening.
The only click I get now is to unlock the steering wheel. Everything after that is the same click/ resistance free turn of the key and nothing g happens.
Anyone have some ideas?
The neutral safety switch might be out of adjustment. Try starting it in neutral (auto trans. ).
If you're not getting any resistance when turning the key, it sounds like the rod connecting the key cylinder to the actual switch (mounted on the steering column near the firewall) might have become disconnected on one end or the other?
I had the same thing happen in terms of "No Resistance" when rotating the key. The problem ended up being the sector gear and a broken gear rack.
The gear and rack are inside the left side of the steering column opposite the key. There is a small shaft that is engaged with both the keyed tumbler and the sector gear. When the key is rotated the gear rotates (which is in mesh with the rack) causing the rack to pull up (move toward the driver in) a linear direction. There is a rod attached to the rack that travels down inside the column. This rod is also attached to the actual ignition switch. The switch is mounted external on top of the steering column behind the lower dash pad. When the rack pulls up the switch is actuated energizing the electrical circuit to the starter solenoid.
Here's what the gear and rack kit looks like. O Reilly can get them.
bradleyb66 (04-01-2019)
Platinum Supporting Vendor
That one will not work on a 76. The 69-76 rack and sector kit is not available. The 77-82 is not a suitable replacement either. The sector gear for the 69-76 just came out but you can't use the rack from the 77-82. You are going to have to disassemble and see which one is bad. However before you do that, just the ignition switch, the actual electrical one down toward the lower half of the column. You will see all the wires going into it. Have someone turn the key why you look at it and see if the rod moves. If the rod is moving then the problem is that switch. If the rod doesn't move then you are going to be taking the column apart. If you are not sure about how to do that, you can send it to us and we can do it for you.
Thank You
Justin
Thank You
Justin
Try putting forward pressure on the gear selector and you turn the ignition switch. My car is also a 76 with tilt/tele and currently has this same issue but I haven't fixed it because to me it's another theft deterrent..
