How much vacuum to raise headlights?
Old 04-23-2019, 10:48 AM
Surfer69
CF Senior Member
Surfer69's Avatar
Default How much vacuum to raise headlights?
I've got a problem in the vacuum lines so I bought a HF vacuum pump to check it out. Would like to know specs or where to find on how much inches of Mercury it's suppose to take to raise headlamps and/or wiper door? Thx
Surfer69 is offline
Old 04-24-2019, 04:23 AM
rvzio
CF Senior Member
Support Corvetteforum!
Car is a 69? New actuators? any new parts? Leak in tank? a lot more questions before you start. What exactly is not working.
rvzio is offline
Old 04-24-2019, 09:39 AM
zwede
CF Senior Member
zwede's Avatar
1" is enough to operate them, just slowly. I've tested with a hand-pump and be aware you need to pump a lot for something to happen.
zwede is offline
Old 04-24-2019, 09:54 AM
Tiger Joe
CF Senior Member
i thought you weren't supposed to test the system with an electric vacuum pump?
Tiger Joe is online now
Old 04-24-2019, 10:35 AM
Surfer69
CF Senior Member
Surfer69's Avatar
I pumped the hell out of it at the main hose to lights by brake master and nothing held so must be a leak. I will attack each component separately. I suspect one of the lights diaphragms must be shot.
Surfer69 is offline
Old 04-24-2019, 12:53 PM
lionelhutz
CF Senior Member
lionelhutz's Avatar
zwede is right, it doesn't take much but they go very slowly. Dad's car had a leak and while we were diagnosing and connecting up various parts looking for a leak we were disconnecting the tank so it had no vacuum. With no vacuum in the tank, a light would move as soon as the vacuum hose was connected at the same time vacuum was starting to build in the tank.
We found a small rust hole in the bottom of one of the actuators. A little JB Weld and it's worked fine since.
lionelhutz is offline
Old 04-25-2019, 04:56 AM
7T1vette
CF Senior Member
7T1vette's Avatar
Received 1,057 Likes on 953 Posts
Most likely cause is worn-out vacuum relays (rather than the actuator cans). To test, just disconnect the vacuum feed on the relay and hook it to one of the actuator fittings so see if it works much faster (move hose to other fitting to close the housing). If it works well, replace the relays. If it works the same, replace the actuator[s] as needed.
7T1vette is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
