Where to get air bleeds?
could you elaborate, air bleeds to be used for what purpose?
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can get a set of torch cleaning drill bits....you can use them to drill. Lots of tiny bits. If you go too big...you can epoxy it and start over. Or you can order blank non-drilled ones and do what you want.
JIM
JIM
Received 3,043 Likes
St. Jude Donor '05
aed sells them, sure other holley builders do also.
One thing I learned is when you increase the air bleeds and really emulsify the fuel and you end up changing the fuel jets to compensate.
https://www.summitracing.com/nv/part...0qft/overview/
https://www.hotrod.com/articles/tuning-with-air-bleeds/
https://www.holley.com/blog/post/car..._bleed_basics/
Old Pro Solo Guy
George,
I´m in process of tuning the new AED carb. Got an oxigen Sensor to check A/F ratio and jetting is almost done. Now I have to fine tune it. I´m in contact with Lars and the tech support of AED. Thank you for the offer of shipment but I think, I will drill them because I have access to a lathe and verry small drills. And thank you for the verry helpful links also!
Best regards, Günther
Very impressive Gunther, I love the mixture of pure restoration (tower hose clamps, Ign. shield) and then AED pieces, cool! I think maybe more impressive is a European car owner working on Air Bleed tuning (not for the faint of heart, but not impossible)
I don't mean to offend, but most of the European folks (not counting the many Vette Forum folks) I meet through my Job would never think about doing something like that. (I'm a Field Service Engineer, so I meet some pretty hands on folks).
Hello!
You are right. Many of them just buy a carb (most of the time too big), put it on the engine and don´t care about tuning the stuff. And then they complain, it´s not running good, stumble, hesitations and poor gas milage and so on.
73racevette (05-02-2019)
Cruise-In IX Veteran
I personally order brass set screws from McMaster and drill my own. https://www.mcmaster.com/set-screws
