Smog hole in the manifold needs repair 1968
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I posted this in "General"- maybe it's better addressed here.
In an attempt to plug the smog holes in the manifolds, the previous owner had run a bolt all the way through one of the holes, and past the"lip" that retains the exhaust tube extension, and now that hole is without its lip. Has anyone dealt with this problem and made the necessary repair? Thank you.
cor66vette (04-28-2019)
Are you worried that the bolt won't seal if there isn't a lip to seat against?
Maybe use a short bolt with some hi temp anti seize and torque it down tight so that it seals against the bottom of the bolt head.
I used standard pipe plugs, which should have a tapered thread as opposed to straight threads on a bolt, on mine. Then ground them off flush with a peanut grinder. They now look like undrilled bosses.
Just looked at the post above. Putting on the smog tubes or deleting?
Gotcha... I am assuming you are putting the air stuff back on because you live in a state that smogs your car and the previous owner either didn't or didn't care about the smog stuff. If that is the case given that you said the PO has drilled and tapped the manifold for the bolt in question I would source a new or new to you manifold. That could be repaired but you'll go through more trouble than its likely worth.
Depending on what year your car is you can source a PAIR of NEW manifolds for about $200 or so off rockauto. Might find them cheaper still
cor66vette (04-29-2019)
If somebody can find a repair kit you can install yourself that would be great, but from what I’ve found it would have to be fabricated which means you’ll have some money wrapped up in it.
Non functioning with no need for the extension tubes is the way to go. No need for a functioning smog system. If you must have it work, the bushing idea in that drilled out hole sounds like the best idea.
cor66vette (04-30-2019)
I think that lip is what the flared tube seats against. And without that lip that tube is never going to seal. So it's not really repairable for functional. it can be repaired so that it looks functional. You could probably buy some bushing with the correct inverted flair on the inside and a pipe thread on the outside. But then you would have to drill and tap to the very large pipe thread size and the bushing would be there and rather obvious. If you had to have working emissions this would be something to consider.
I'm concerned about leaks, though. With that over-sized hole, I don't know if the tubes can screw in securely. Once I have the tubes, I can test the treads and check for leaks. I was told that the threads on the tubes I'm getting are 1/2 x 18nf flat bottom- a stranger than strange thread size, in my case anyway. Of all the taps I have, I do not have that size and they're not cheap, so buying one for a one-time use will just add to the cost of this project, and my budget for this has already been laughed at. I'll try to borrow one for this job, and try tapping the existing threads and see how many OR IF any of the threads are good, and go from there.
Your comments are appreciated and understood, and it looks like non-functioning may be where this is going. If I decide otherwise, I'll put the smog system to the side, and try to secure a set of usable smog-ready manifolds.
I'll update this post with the outcome of these shenanigans.
Thank you all.
Thank you all.
This should be the end result for your engine. Looks pretty and doesn't work. I actually had one hole in the R-side manifold damaged as your's.
Manifold trees were blocked, vacuum line to diverter valve blocked and vanes knocked out of the pump.
Again, if you are Determined to fix that drilled out hole, do as recommended by Sayfoo.
Here is the seal of the exhaust gas manifold to tree; tree tube flare to extension tube flare, the lip only serves to hold the extension tube in place.
^ ^ ^ Thanks for those pictures. With each new pic I see, I have a better understanding. The problem I see with the screw blocking the tube (your last picture) is that in my case, without a lip in the hole, that screw can fall out- unless yours is actually screwed in place in the tube. Also, how did you work around the damaged hole?
Your manifold looks pretty corroded, and might not seal if you had the correct parts- for restoration. Manifolds (non Corvette) are relatively cheap and available. Just replace this one and save for later.
^ ^ ^ The pictures do make them look pretty shitty, but they're actually not bad. If I have issues with the smog tubes sealing, then yes, I'll look for another set.
