Help! Rotor rivets popped off of hub
I was trying to finish my new front end rebuild and while I was using a shop press to press in my new Timken bearing race into the hub, it popped, scared the $@#* out me, and it looks like all 5 of the rivets securing the original brake rotor came clean out and the hub dropped an inch onto the lower part of the press. I marked the location of where the studs go into the rotor so as not to change the orientation and hopefully limit any change of the rotor runout. Can I take it to the machine shop tomorrow and have the remaining rivets drilled out of the rotor and replace them with bolts without any issue? and should I remove the other side and have the same done? Maybe its time to get some new rotors?
Couple of options-- just knock the rest of the rivets out and forget they were ever there. Or drive out the rest of the rivets and drill and tap for bolts. You'll need to countersink the bolt heads. Either way, you should check the runout and adjust it as needed.
RocketNerd (05-01-2019)
Thanks for the help everyone, I decided that i was going to have the local machine shop remove the rivets on both front rotors and since I just finished the front suspension rebuild I will be replacing them with the powerstop cross-drilled and slotted rotors (I've wanted to upgrade them) and will pickup my dial indicator to check the runout with the new rotors installed. Any other recommendations on what I need to do when I replace them?
GTR1999 has sprinkled around the internet the instructions for countersunk flathead screws to hold the rotors. If you can't find the info, PM him. I bought a set from McMaster Carr, as they are not a common size, but I have enough for both cars.
He also has the DIY runout method you will want to follow, vs cutting a new set of rotors.
Back when the C3 was a new car disc brakes were relatively new on passenger cars. Because of design choices rotor runout is a pretty critical item. Not 100% certain of this but I could see it being done with the thinking that during the initial build of the car the rotor and hub were checked together because of of the runout concerns to eliminate tolerance stack up.
The rivets are a quickie way to hold the 2 together while being assembled-in St Louis.
