Another idea for a ridged rear end bar!
Bar from bottom of diff spring mount forward. Lots of attention to detail. Drag vette 1/2 shaft cages required by NHRA. Note aluminum disks on each end of the diff cross-m? They are for solid mounting the diff.
Metalhead140 (05-02-2019)
Those have been around for awhile. Motion had one back in the '60s.
Received 3,043 Likes
St. Jude Donor '05
Wouldnt that make the pinion want to climb the ring gear? Can see its function ,not a bad idea
That's the idea-- normal torque the pinion wants to climb the ring. The bar is to mount the case a little more solid and keep it from seeing the torque and twisting things.
