Vintage Air central bezel not fitting
Old 05-11-2019, 01:31 PM
gwgwgw
CF Senior Member
gwgwgw's Avatar
Default Vintage Air central bezel not fitting
Installing vintage air in my 69. Their center bezel with air vents is not fitting with my center bezel above
the center gauges.
Anyone else have this problem
There is a difference in the rear bottom lip
I have a picture of the original plus the comparisons to the VA
Glenn in San Diego
gwgwgw is offline
Old 05-11-2019, 08:15 PM
twinpack
CF Senior Member
twinpack's Avatar
Can really offer you any help except the obvious to call Vintage Air. I have a 68 and trying to decide if I should install the A/C. How have you found the project so far minus the vent fitment. Where did you purchase from.
twinpack is offline
Old 05-12-2019, 01:00 PM
20mercury
CF Senior Member
20mercury's Avatar
My 2 cents; I want to remember having to cut the lip or modify on one of my VA installs too.
Thought for you and what I finally did on one of the VA installs; I made a transition piece out of alum roof flashing (make the design with paper and scissors first to understand how it needs to fold up), duct tape it up and reuse your existing bezel vent. I thought the existing bezel vent looks better anyway.
Hope this helps.
One more suggestion, I found it a challenge to get the full charge into the system (and so max cooling) until I exactly followed VA instructions for charging (4 fans in front of the radiator, fast idle, etc. Also used a postal scale to determine charge weight). Good luck and a/c is fully worth the effort in Louisiana and CA too I would imagine.
20mercury is offline
gwgwgw (05-13-2019)
Old 05-12-2019, 09:24 PM
bluegtp
CF Senior Member
bluegtp's Avatar
Hope this helps.
100% agree in Louisiana weather. 10 years w/out ac in my c3 and this year i finally have it and makes driving in the summer so much better.
I'd say call va..... everything I've read is they have good customer service. Good luck
bluegtp is offline
Old 05-13-2019, 02:15 AM
gwgwgw
CF Senior Member
gwgwgw's Avatar
Thanks for the replies
I have reached out to VA and they are checking for me.
i also have eyed modifying the existing bezel as mentioned above
Glenn
gwgwgw is offline
Old 05-13-2019, 03:16 PM
carriljc
CF Senior Member
carriljc's Avatar
Some ideas for you. I did similar to this thread at first with a used tube of RTV and attached to back of a stock a/c vent bezel.
https://www.corvetteforum.com/forums...post1571981113
It worked well enough that I kept it like that for a while.
Subsequently I fabricated and angled contraption so I could maximize air flow. Just some ideas for you ....
carriljc is offline
20mercury (05-13-2019)
Old 05-16-2019, 10:18 AM
rugerm44
CF Senior Member
Default vent
mine came this ridiculous single vent for the center vent so I bought original one and made fiberglass duct adapter for it.
Originally Posted by carriljc View Post
Some ideas for you. I did similar to this thread at first with a used tube of ​​​​​​​RTV and attached to back of a stock a/c vent bezel.
rugerm44 is offline
Old 05-18-2019, 08:56 AM
BigBill94
CF Member
Support Corvetteforum!
BigBill94's Avatar
Given their name recognition and how well the cooling module fits, you would think they would come up with a better system for the various vents... Nope. Dealing with those hoses and center vent SUCKS. 10lbs of **** in a 5lb bag.
BigBill94 is offline
Quick Reply: Vintage Air central bezel not fitting
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
