6 speed Manuel transmission
Old 05-14-2019, 07:26 PM
69ttop502
CF Senior Member
69ttop502's Avatar
Originally Posted by jb78L-82 View Post
I love the nonsense that you need a giant BB engine to utilize a 6 speed OD manual. NOT TRUE!
My 355 L-82 with AFR heads, roller cam and 10.2 compression can pull effortlessly with 3.70 gears and a 1:1 fourth gear below 1,000 RPM (700-800 RPM) with zero bucking from the engine/tranny. Any big V8 (a 350 is a big V8-BTW-5.7 Liters) can utilize a 5 or 6 speed OD with no lugging or bucking issues. Where does this stuff come from? Unless you have an engine with a cam operating range of 3,500-7,000 RPM an overdrive tranny should not be a challenge. A low torque 4 cylinder 1.8 liter engine is another story.
This stuff comes from the people that have cams that are not happy at that low of an rpm. My solid roller 502 does not like it under 2400 rpms. Therefore a tall overdrive gear would not work. That’s the reason I went with a 3.08 rear gear and a 5 speed with a 1:1 fifth gear. Not every V8 will work with a deep overdrive. Gears and cam make more difference than displacement. More than one way to skin a cat. I like the Richmond 6 speed in that you have a close ratio 5 speed with an overdrive. Most of the overdrive 5 speeds and 6 speeds lose the feeling of a nice close ratio transmission.
69ttop502 is offline
The following 2 users liked this post by 69ttop502:
bmans vette (05-15-2019), Metalhead140 (05-17-2019)
Old 05-14-2019, 07:32 PM
OldCarBum
CF Senior Member
I like the TKO-600RR close ratio 5 speed with the 0.82 fifth gear.
I'll be running it with 3.08's behind my 496.
2200 rpm @70 mph will work great with my cam cruising down the highway.
OldCarBum is offline
qwank (05-14-2019)
Old 05-14-2019, 07:36 PM
qwank
CF Senior Member
qwank's Avatar
I you have a 3.08 or higher rear gear you could get away with using a Richmond 5 speed. I have one and it's great with my 2.87 rear gears
qwank is offline
Old 05-14-2019, 07:40 PM
carriljc
CF Senior Member
carriljc's Avatar
BTW--- I don't think you would have to do any permanent modifications to install the Richmond 6 speed. Just looked and I installed mine almost 21 years ago. If I did not want to cut my crossmember then I could have installed it from the top attached to the engine. It fits in there nicely. Nevertheless I'm glad I made my crossmember removable.
I got a "conversion" u-joint to mate output yoke with stock driveshaft. Anyway, if you end up finding one then I can give you more pointers and part numbers.
My 1st thru 5th are close ratio--- I selected them when I ordered it from Summit Racing. The 0.62 overdrive is just about wonderful for cruising. It ends up equating to about a 2.54 rear end. It's easy to find yourself going too fast now.
carriljc is offline
Old 05-14-2019, 07:45 PM
BLUE1972
CF Senior Member
BLUE1972's Avatar
I have the Silver Sport 5 speed kit in my 71, fit perfect - no mods. They give you the correct new driveshaft.
355 rear and .6 overdrive, at 80 mph about 2000 rpm.
BLUE1972 is offline
Old 05-15-2019, 08:51 AM
jph79
Junior Member
Ok thanks for all the good info. I think I'll go with the 5 speed cause it fits better and this car will not see a track. Might put in in a lower rear end in time cause it would be nice to smoke the tires some in first. And second. Is that possible with with thie 5 speed? Should have said I do have a 335 with 200 cc heads and and a xe cam. But still have no interest in cutting my tunnel
jph79 is offline
Old 05-15-2019, 10:57 AM
OldCarBum
CF Senior Member
My Tremec TKO-600 has a 2.87 first gear and the Tremec 5 speed has a 3.27 first gear.
You should be able to light up the tires with either.
Old 05-15-2019, 07:06 PM
cuisinartvette
CF Senior Member
Received 1,223 Likes on 1,120 Posts
St. Jude Donor '05
x2 they are a noticeble difference from say a Muncie 2.20 low (which feels tall). That 2.6 or close feels just right...even with a 4.11 you wont be shifting gears halfway across the intersectino. I see people post that not sure where that info is coming from unless they never take their engine over 2k.
When funds allow Im having the Z06 close ratio gearset installed in this T56 along with a Viper input shaft which has been collecting dust.
cuisinartvette is offline
Old 05-18-2019, 04:17 PM
Tom_K
CF Senior Member
I just finished a 5-spped Tremec in my 68 427 4.11 rear car
It is perfect. Just like original except that satisfying shift into 5th once at cruising speed.
The car is now a perfect blend, boulevard cruiser and highway flying,
I went with Silversport they were great to work with.
Tom_K is offline
Old 05-20-2019, 12:17 PM
509 rat
CF Senior Member
I agree with you.with my 370 gears my 6 speed works great.The only reason im going to a 411 ratio is to utilize more of my 5th and 6th gear.I dont want to go faster than 125 mph, maybe a high 12 second 1/4 mile car , if that makes any sense.
509 rat is offline
Old 05-21-2019, 07:48 AM
derekderek
CF Senior Member
multiply 1st ratio by final drive ratio. called launch ratio, 9 to 10 is streetable. 11 is drag strip. on the street unless really winding it out, you will be hitting second almost immediately with 11:1 launch.
derekderek is offline
Old 05-21-2019, 12:27 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Less may be ideal if its stock or mild.....10.9 first below never shift before I get out of the intersection like some say...unless they are shifting at pretty low rpm?
4.11 26 in tire 2.66 1st just pussyfooting it around. 2:15 5th towards the end use 5th and 6th....4.11 is not that low. In the primaries barely the entire time burning off old pump gas. Hope this helps.
Old 05-22-2019, 08:53 AM
  #33
PainfullySlow
CF Senior Member
PainfullySlow's Avatar
https://www.youtube.com/watch?v=oOZFtGkcfgc
Thanks for this, and just what I am looking for. It cemented what I will be going with for gearing. Loving the ZZ Top keychain. I still have mine from my first live concert ever back in the 80's :-p
PainfullySlow is offline
Old 05-22-2019, 03:08 PM
  #34
jb78L-82
CF Senior Member
jb78L-82's Avatar
My 10 C6Z06 turns 1,800 RPM at 80 MPH in 6th which is an absolutely beautiful thing after driving the 78 L-82 with 3.70 gears in 4 th on the highway. The LS7 can turn 1,800 RPM all day long at 80 mph AND get 28 MPG.......................incredible.
If I had a steep OD in my 355 L-82 with the roller cam and AFR heads, I could easily turn 1,800-2,000 RPM all day long as well on the highway and probably get 23-24 MPG with the Holley 4175 650 CFM with the small primaries, just the qjet . The gearing is the biggest limiting factory to great MPG's in these cars.....
jb78L-82 is offline
Old 05-22-2019, 10:08 PM
  #35
cuisinartvette
CF Senior Member
St. Jude Donor '05
If you have EFI a plus...or small cam big stroke. KNow a # of guys with mild motors that thought wiht a 3.08 and 700r they would lug it and get good mpg. They alll regeared at least .50
Quick Reply: 6 speed Manuel transmission
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
