rear end gear ratio choice
I have a 79 vette automatic. Purchased a supposedly 383 stroker with approx. 380 hp and 415 torque.
Car runs much beefier than the original but still can't spin the tires.
checked my rear end to find it is a 305 sucks!!
I would like to smoke the tires a bit and stick me in the seat.
SO the question... 355 or 373.
Does anyone know what rpm the 355 would be at 70mph vs the 373.
Don''t really want to be wound up like heck at 70 but I do want some beef.
Any help woiuld me appreciated.
I have 3.70 in my 78 and at 70mph it reads at 3200rpm.
Punch some numbers into this...
https://spicerparts.com/calculators/...rpm-calculator
Craig
there was no 3.05 ratio
you either have 3.36, 3.55, or 3.70.
how did you go about determining the ratio?
a 3.55 at 70 mph is about 3,100 rpm with 27" tires
a 3.70 at 70 mph is about 3,500 rpm with 27" tires
bmans vette (05-22-2019)
You probably have the 3.08 ratio. That being the case, the 383/380 horse stroker should still easily spin the tires........I'd look into engine tune, not the rear gear. 415 torque should rip any street tire loose.
jackson (05-27-2019)
lets pretend you have 305 like you say. going to a 355 will add 500 rpm more to the same speed you are doing now. so 70 mph with 305 is 2900, with 355 its now 3400, with 373 its now 3600..Are you sure the speed o is correct on that? When you change tire height it affects the speedo reading.
Yes the speedo is correct. I can't help but think the 355 or 373 would stick you in the seat much better. Just wasn't sure which would be the best. Never even really go 70 mph. Just bring it out for short cruises every now and then.
How tall are the tires on the rear or do you know the size?
What is the first gear ration of your transmission?
Multiply the first gear ratio of your trans times your rear end ratio and see what you get.
8.5 to 9.0 is pretty good for a street car and should light your tires.
9.0 to 10.0 is getting low and should give you excellent acceleration off the line and you should light the tires effortlessly.
Anything over 10.0 is useless for the street.
The difference in tire size unless you are running 34" mudders, really won't change the overall results.
The difference in rpm level at a given speed between 3.55 gears and 3.73 is pure arithmetic. 3.73 / 3.55 = 1.05. Therefore if you're doing 3,000 rpm with a 3.55 gear, you would be doing 3,150 with 3.73 gears, at the same speed. (3,000 x 1.05)
