Odd distributor leak repair and new aluminum valve covers.
My distributor has the oddest leak. It leaks oil up the shaft and into the distributor and then leaks out dripping on the bell housing. I have never seen a leak like this before on any distributor.
I took it out and took it apart and nothing looks unusual. I decided to try a fix by adding an o-ring to go between the cup on the shaft and the topp bushing on the housing. I used a .070" cs o-ring, greased it up good and when I put the shift in, it stopped short. Just a light push and I felt the o-ring go over the top of the bushing. It doesn't affect the lash and it didn't add much drag when turning it. Will it work? So far. I took it on a long drive and no oil leak yet. Will it last? To be determined.
I also got tired of fighting the chrome stamped steel valve covers and leaks from them. I have tried every type of gasket and sealer combo on them and even had the long torque spreaders on them, and the leaks stop for a while and then they return again and make a big mess and oil spots in my garage. I bought a pair of finned aluminum valve covers and used rubber with steel insert gaskets. So for dry as a bone.
So the big question, do the new finned valve covers look better or did the old chrome ones look better? I'm undecided yet.
Mike
Mike
Mike,
Do not have a clue what the chrome stamped steel looked like but can find no fault of anything in your engine compartment; the valve covers look great. Judging by what I believe to be a hydro-boost and other things under the hood, appears to be a serious build; care to share some of the details?
Are you still located in Spring Park - google maps shows that to be on Lake Minnetonka? I often aim for that area when venturing out from the twin cities in my 69 convertible......on both nice days of the year.
Don
Don
Much bigger fan of the finned covers. Aluminum > stamped steel all day long here. The plain chrome covers just look cheap in my my opinion.
v2racing (05-24-2019)
At the top of the housing, isnt there supposed to be a felt washer and seal to prevent oil leaking out?
Look at some exploded diagrams of HEI distributors.
I like the finned,. Never been a big fan of stamped steel valve covers. Cast aluminum is superior and that's why some covers are $19.95 and some covers are over $200.
I like your oil catch can, but I question why you have suction off of both valve covers in the first photo. One suction hose to the catch can and one suction hose to the air cleaner.
If both covers have a negative air pressure, how is fresh air being introduced and replacing the air that has been evacuated from the crankcase? In other words, you can't have two outlets without one inlet.
In the bottom photo, a valve cover breather is in place which would then be fresh air inlet.
Mike,
Don
Don
There is still a photo of my chrome valve covers in my signature.
Mike
Received 2,127 Likes
v2racing,
Your train of thought and mine are two different concepts. You say your passenger valve cover hose goes to the air cleaner base, no vacuum. But isn't the entire air cleaner under negative air pressure or in laymans terms, it IS under vacuum when engine is running? Your drivers side valve cover is under vacuum too, going to a oil catch can. The way I see it, BOTH valve covers are being sucked on by vacuum with no inlet available to allow fresh air in for the crankcase.
You see what I'm saying? Two outlets, no inlet. I like the catch can setup, but I don't believe yours is working at full potential.
Supposed to be a felt ... seems like a plastic "retainer ring" snaps in atop the felt?
-edit- ... I prefer cast aluminum ... not fabbed ... cast ... your finned cast look great.
v2racing,
Mike
HeadsU.P. (05-25-2019)
v2racing,
v2racing,
It takes 13.6”of water to equal one inch of mercury. So the engine developers no less than 95 times more vacuum than the air intake assembly could hope to.
in other words its of zero concern.
at periods of WOT the flow will reverse and pressure will actually be produced due to blow by and non-existent vacuum, venting crankcase pressure out what would normally be the “intake” for the crank case ventilation. This is one reason why it’s connected to the air cleaner.
Hey V2Racing, myself and other have pointed out to you that you are missing parts concerning your oil leak but this fact seems to be drowned out by all the comments about your valve covers.
Mike
Yes. This is an aftermarket distributor and all it has in a nylon washer in the top. I have 2 of these distributors and they are both the same. The o-ring I put in the top seems to have cured the issue for now. I will keep a close eye on it and if it starts to leak again, I will find or make a felt washer.
Mike
Mike
v2racing (05-25-2019)
On second thought ... ridiculous prices on felt washer ... they must not be asian ... instead must be manufactured either JPL caltech or diamond district 47th st mid-manhattan
You need some black in that compartment, black crinkle with the fins in raw alum (like the old weiand/edelbrocks).
Seems like you are on the right track for the oil leak.
Location: Las Vegas - Just stop perpetuating myths please.
I think those finned v/c's look great. But like mentioned before if your concerned 'bout esthetics black hoses would look better than colored or clear.
Something that's not difficult to do but helpful for diagnosis of the crankcase ventilation is to tee into each line with a vacuum gauge to see what vacuum you really have at each location. Takes the guessing out of understanding the working system. And you may be surprised to find some positive pressure in locations where it should be under vacuum.
A vacuum gauge/test is often overlooked but it can show you restrictions in the intake ducting also. Any vacuum reading between the air cleaner and throttle body is a restriction. Any vacuum reading between the atmosphere and the air cleaner is a restriction in that duct also.
Hope this can help.
Hope this can help.
Hope this can help.
Hope this can help.
Mike
