sill plate screw holes fix?
Old 05-24-2019, 11:43 PM
stingraygene
stingraygene's Avatar
Default sill plate screw holes fix?
couple my sill plate screw holes are too big now. what is a solid good fix? I read somewhere about jb weld.. but is their a more permanent fix? I was thinking some kind of metal plug that expands on underside of hole or something like that?
Old 05-24-2019, 11:54 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You could always weld it and re-drill them for a perm fix, but may be a little extreme.
Old 05-25-2019, 12:35 AM
Peterbuilt
Peterbuilt's Avatar
Received 1,244 Likes on 965 Posts
Default Kiss
Would a drywall anchor work?
Old 05-25-2019, 12:37 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
A 'satisfactory' semi-permanent fix is to plug the existing holes with JB Weld stick/putty epoxy (5-minute work & harden time), then drill smaller holes. BUT, you then have to refrain from torquing the he!! out of the screws to hold those flimsy aluminum sill plates down. Just a snug-up will do it.
Old 05-25-2019, 08:15 AM
PainfullySlow
PainfullySlow's Avatar
I would use something like this. You could weld in place or use epoxy for added insurance.
https://www.amazon.com/30PCs-Stainless-Insert-Nutsert-4-20UNC/dp/B077GQLQZ8/ref=asc_df_B077GQLQZ8/?tag=hyprod-20&linkCode=df0&hvadid=242024233652&hvpos=1o4&hvnetw=g&hvrand=7067602299430068345&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003219&hvtargid=pla-396303543009&psc=1 https://www.amazon.com/30PCs-Stainless-Insert-Nutsert-4-20UNC/dp/B077GQLQZ8/ref=asc_df_B077GQLQZ8/?tag=hyprod-20&linkCode=df0&hvadid=242024233652&hvpos=1o4&hvnetw=g&hvrand=7067602299430068345&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003219&hvtargid=pla-396303543009&psc=1
Actually, I am certain that I will have to do this as I remember stripping a few as I tried to take off the original rusted ones so thanks for bringing this up.
Old 05-25-2019, 08:44 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by Peterbuilt
...Would a drywall anchor work?...
Yep. I'm using three of them.
Old 05-25-2019, 08:58 AM
croaker
croaker's Avatar
https://www.amazon.com/30PCs-Stainle...03543009&psc=1
I’ve looked all over locally for these. Most places don’t have a clue.
Old 05-25-2019, 10:45 AM
7T1vette
7T1vette's Avatar
The sill plates had sheet metal screws in them from the factory...not machine screws. Either will work, but machine screw retention strength is not needed for the flimsy sill plates.
Those inserts (or hardware store "T" nuts) are great for repairing damaged/missing threaded inserts for mounting the rocker panels. The original inserts were #10-24 threads.
Old 05-25-2019, 12:00 PM
Buccaneer
Buccaneer's Avatar
Like mentioned, I don't think that they will work with a sheet metal screw? IDK, maybe they will, they are cheap, give em a try.
20mercury
20mercury's Avatar
Default Ditto here, that is what I use.
Ditto here, that is what I use. Also will sometimes just place a wire or plastic weed eater line cut piece in the wallowed out hole to reduce the id and give the screw something to bite into. Hubba Hubba Bubba!
Hope this helps.
Old 05-25-2019, 03:25 PM
Richard454
Richard454's Avatar
Received 3,216 Likes on 1,729 Posts
Harbor Freight has them- works great on the smaller sizes- a little over $20 Try the term rivet nut or rivnut- and you'll find them.
https://www.harborfreight.com/45-pie...-kit-1210.html
I use them for all sorts of things...
Hope this helps.
Man...and to know you went to that North Avenue Trade School!!!
The following 2 users liked this post by Richard454:
caskiguy (05-31-2019), LenWoodruff (05-26-2019)
Old 05-25-2019, 04:19 PM
20mercury
20mercury's Avatar
Hi Richard, thanks for the compliment! I want to remember it was called Bubba 101, maybe, LOL's!!!
BTW, you going on the Hot Rod Power tour this year? Looks like it is going through some great country!
Old 05-27-2019, 01:18 PM
crf311
crf311's Avatar
Harbor freight has the whole setup.
Old 05-27-2019, 07:49 PM
BLUE1972
BLUE1972's Avatar
Received 1,121 Likes on 731 Posts
Take a carter pin bend the legs 90 degrees and insert it into the hole, head first.
Depending on how goobered the hole , a small usually works fine..
Screw tightened up fine...
Old 05-28-2019, 12:38 AM
standardbyke22
standardbyke22's Avatar
if i remember correctly the hole around the fiberglass is around 5]16-3\8 around the sill plate holes into the rocker channel clean/scuff the metal up turn up the welder and burn that hole shut, done and permanent. drill and run the screw through. no screwing around or looking for inserts, etc
Old 05-28-2019, 08:18 AM
jpatrick62
jpatrick62's Avatar
I narrowed the hole in the fiberglass sill using a small fiberglass fill - worked great and gave the screws something to bite into.
To sill plate screw holes fix?
Quick Reply: sill plate screw holes fix?
