Rear suspension higher on one side
I recently installed a new 3.55 differential in my 77 Corvette along with new spring mounting hardware. I reused the original 9 leaf spring. The car has a noticeable height difference on either side now, maybe an inch or so. What could cause this condition. The new end bolts are secured with a cotter pin, so there is no real adjustment to them.
Crm318 (05-27-2019)
Post a pic of the rear suspension.Not a good idea to adjust spring independently because you will pre load more
one side over the other.
Well, I turned the spring around 180° and even installed new 8" spring bolts and the car sits at the exact same height and even has the same height inconsistency as before. Nothing at all has changed.
