Easiest way to remove a big block from a junk car?
#41
Eldarado's are all front wheel drive so the transmission isn't anything of use unless of course you have another Eldorado. I believe the transmission is similar to the Toranado but again no value.
#42
OP, what did you end up doing with your reprieve of several weeks?
Even if you don't intend to restore it (and I certainly wouldn't), if the car can be made driveable, can you go have some stupid big block fun for a summer, then scrap it?
I'm sure this guy spent more on the headlights and the wrap than your car is worth, but you could go this route with some spray paint.
