Brake lines
what i need to find out is the difference in the hard brake lines between the 73 and 74 models? Is the proportioning valve /distribution block different, or mounted in a diferent location? I have a complete set of stainless steel line for a 73 that i would like to use on my 74 coupe.
is this possible with minor mods or using the 73 distribution block?
:confused: :confused:
I don't see why it isn't possible...... Bending stainless isn't that hard, but don't cut the line thinking you can double flare it...... Double flaring SS is very hard. You need good equipment and you still have a chance of causing fatigue cracking in the flare.
