1969 Starter Wiring ID
Old 06-10-2019, 10:29 PM
LeMans Pete
CF Senior Member
LeMans Pete's Avatar
St. Jude Donor '13-'14
Default 1969 Starter Wiring ID
My wire colors are a bit irregular, can you help me ID the wires and their location on the solenoid, going from left to right, based on their gauge and connection? If it helps, I made a note in the AIM that the yellow (#4) appears to go to the S terminal.
LeMans Pete is offline
Old 06-10-2019, 11:24 PM
Peterbuilt
CF Senior Member
Peterbuilt's Avatar
All the red wires connect to the TOP solenoid terminal.
The black wire is a ground and connects to a starter or bell housing bolt.
Your yellow connects to the 'R' terminal on the solenoid.
Peterbuilt is offline
blue427 (06-12-2019)
Old 06-11-2019, 11:09 AM
bradleyb66
CF Senior Member
Support Corvetteforum!
bradleyb66's Avatar
But I think one of those wires needs to connect to the 'S' terminal? Since the colors seem to be incorrect, I'd connect #3 to the large terminal and #2 (black) to the ground as Peterbuilt suggests, then use a test light or multi-meter to see which of the other two wires has 12 volts only when the key is turned to the 'start' position (and clutch pressed if you have a manual trans). The wire that has 12 volts only while the key is in the start position will go the 'S' terminal, and the other wire should be the one that goes to the coil?
bradleyb66 is offline
Old 06-11-2019, 06:12 PM
LeMans Pete
CF Senior Member
This would be the smart approach. I don't agree that all the reds stack on the middle post, as they won't all fit (both in diameter and length).
Like I said, the only note I did make was that the yellow connector wire goes to the S terminal. I'm mostly confused where the black one goes.
I do already have the large black ground wire from the battery mounted to the starter with the secondary support to the bellhousing if that makes a difference.
Old 06-11-2019, 06:20 PM
bradleyb66
CF Senior Member
bradleyb66's Avatar
I'm fairly certain that the black one is ground, as PeterBuilt said. I've seen several threads where that wire has incorrectly been attached to the starter terminals, and things stop working. But, with the other wires having incorrect colors, who knows what Bubba did here. Maybe a picture of your current ground wire might help?
Old 06-11-2019, 09:21 PM
LeMans Pete
CF Senior Member
Hi Bradley,
I agree that it's a ground wire, just not sure where to ground it?
Old 06-11-2019, 10:39 PM
LeMans Pete
CF Senior Member
Current ground on starter.
Old 06-12-2019, 09:59 AM
bradleyb66
CF Senior Member
bradleyb66's Avatar
I think the wire you are referring to is actually the positive battery cable? Don't let the color fool you - the cable on my 69 is black also, but if it connects to the large terminal on the starter solenoid, then it's the positive cable. The only 'large' ground wires should be from the battery to the frame (right under the battery box), and in the front you should have a large cable running from the frame to one of the motor mount bolts (at least that's the 79 setup - I'm assuming that 69 should be similar, but haven't looked).
As PeterBuilt mentioned, the small ground wire in your first photo (#2) goes to one of the bolts that hold the starter on, or really, any bolt that connects to the block or bell housing in that general area.
Old 06-12-2019, 08:50 PM
LeMans Pete
CF Senior Member
Excellent,'I think you have me straightened out Bradley!
bradleyb66 (06-13-2019)
Quick Reply: 1969 Starter Wiring ID
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
