79 tach pegs on start
When I crank the vette the tach pegs past zero so hard that after a couple cranks it moves the needle thus causing calibration issues. When I remove tach filter and connect direct everything works fine. Tried a new tach filter with same result tach pegs past zero. I have the latest wilcox circuit board and tried a second circuit board with same issue. Do I need the tach filter?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pull the tach and ship it to me...
Willcox
123 E. Maple Street
Jeffersonville, In 47130
Attn: Service Department
I'll test it for you for free and match calibrate it if possible.
But as I tell all others.... years ago analog movement failures were far and few between.... Now they are popping up about 10 a year. If you mail me the tach I can put it on my tester and know instantly if it works or not... but it is the easiest way to know if the issue is the tach or the car.
For the tach to keep pushing upward tells me there may be a failure and the only way to tell is to fire it up on my tester.
Willcox
Willcox
123 E. Maple Street
Willcox
The following 2 users liked this post by Willcox Corvette:
jackson (06-24-2019),
TinCanSailor (06-23-2019)
