Is this a carb problem?
Car starts have to feather gas to keep running. Day previous turned high speed idle to 77 L-82 specs. Idled fine 800 rpm Today hard start keeps wanting to die! Spark plug wires i ohmed out fine changed in let filter on carb , vacumn hoses attached and new, i just want to adjust timing after intake gasket repair! Removed and replaced
On mine the fix was to bypass the distributor temperature vacuum switch (DTVS) between the carb and the distributor vacuum advance. That switch won't open until the the engine warms up, so you have no vacuum advance. It is there in order to reduce emissions when the engine is cold, but it makes it run like you know what. If the issue is only when your engine is cold and you have a DTVS I suggest bypassing it to see if that corrects the issue.
Dementer sole survivor
Received 6,291 Likes
2016 C3 of Year Finalist
Is the choke connected. Are you letting the car warm up at high idle for a few minutes before blipping the throttle to get the choke to release?
If I read your post correctly you haven't reset your timing after an intake gasket replacement. Sounds like your timing is too low and you had to increase your idle speed to compensate.
Engine is stalling cold can not even get it to idle to make an adjustment now. Ran fine when i timed it idle was low so increased it and now this problem!
If you can get it to run at 1000 rpm see if the timing is 36* at 2500 to 3000 rpm without the vacuum advance. If it isnt, adjust it up so it is and then see where you have a stable idle with the vacuum advance connected. If you can get it down to 800 rpm or lower check your vacuum to see if you need to adjust your idle mixture screws.They could be out of adjustment.
You could also just have a good size vacuum leak. If everything else is good you could take some starting fluid and just squirt a little around the base of the carb and see if the idle jumps up, that would be where the leak is. Check all your vacuum lines for cracks and make sure they are tight at their connections
Sounds like you did a number of things at the same time.
The people reading this thread have to know exactly what the sequence of these changes were and exactly after what change did your issue start.
Timed it after intake gasket replaced. Idled a little low so increased the high speed idle on carb to factory 800 rpms. Idle nice then. Shut off car went to start next day and hard start would not idle , could not even get it warm kept choking up, Shut off car check all vacumn lines all new! Carb filter changed,, no leaks visual around intake. We have gas in tank ,spark plugs and wiring correct on HEI cap. HELP!
If you are only having to add a 100 or 200 rpm when you feather your gas to keep the engine running, then it is probably something simple, like a lack of timing or the idle mixture is a bit too lean. Since you say you changed the intake gasket, start with checking your timing. Bump up the idle speed screw on your carburetor to allow the car to keep running in order to check the timing. With the vacuum advance disconnected from the carburetor and the vacuum port plugged ( I just pull the hose of the vacuum advance pot on the distributor and shove a golf tee in the hose on that end) set the timing to about 12-14 degrees advanced. Then see if you can get it to idle around the 800 rpm mark on its own. If it is still needing to be feathered, and your carb has the idle mixture screws accessable ( I can't remember what year they starting plugging off the access to them), then turn the idle mixture screws counter clockwise a full turn to see if that helps.
You may need to reset timing and idle speed and or idle mixture to get the desired settings and tune at this point.
If you need to rev the engine to more like 1500 rpm to keep it running, then you probably have a vacuum leak somewhere after your intake gasket change.
