Auxiliary Fuse Blocks
Old Aug 17, 2019 | 10:35 PM
mitch.1972vette's Avatar
mitch.1972vette
Default Auxiliary Fuse Blocks
Wher are you guys putting your auxiliary fuse blocks and circuit breakers in your C3 Vets? I have a 72 and space is premium - where is yours?
mitch.1972vette
If possible, add pics - they are valuable....
Old Aug 18, 2019 | 11:41 AM
Street Rat's Avatar
Street Rat
I run add on accessories such as fans and electric fuel pump on a second fuse block. Mine is in the engine compartment under the steering column. I have pics but not too clear.
Craig
Old Aug 18, 2019 | 12:15 PM
7T1vette's Avatar
7T1vette
Your primary objective would be to pick a location where you will have good access....for the installation process AND for fuse/relay replacement in the future.
Old Aug 18, 2019 | 01:37 PM
Richard454's Avatar
Richard454
I do my aux fuse blocks relays like you would a subpanel in your home. Put it were you need the power and have the ability to access it when needed.
I'm a big fan of the 280 series fuseblock/relays by Little fuse-
This one is mounted upfront above where the actuator for the headlight was- great place since you are adding electric headlights. It'll fit two SPDT relays or three SPST relays plus fuses. I've got one on each side- relays for the high/low headlights- electric headlight motors-horns-
And waterproof and really easy to access.- these things can fit just about anywhere and are totally configurable-use delphi connectors- everything is easily sourceable.
Another great place is in the storage compartment- I've got one there controlling the fuel pump- reverse lights-power door locks and power windows
Old Aug 19, 2019 | 05:46 AM
mitch.1972vette
That is great advise, what crimping tool do you use for these 280's?
Old Aug 19, 2019 | 07:53 AM
Bikespace's Avatar
Bikespace
I have the same marine fuse panel as @Street Rat, mounted with some relays on the vent/heater fan duct. Lots of room there after the AC delete. I have a 100 Amp fuse at the alternator and a thick cable (4 AWG) that runs to the fuse panel for the individual circuits.
And once again @Richard454 's solution makes everyone else look like an amateur playing around in their garage.
Old Aug 19, 2019 | 08:54 AM
Mooser's Avatar
Mooser
Made a temporary aux panel last year that I'll likely never get back to changing
Ran two relays off the acc and ign mounted beside the steering column
over to two small fuse panels behind the passenger side console extension cover (radio access?)
M
Old Aug 19, 2019 | 06:57 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
mine is mounted right next to the original.
original
auxiliary mounted on a bracket sideways
Old Aug 19, 2019 | 10:04 PM
Richard454's Avatar
Richard454
Thank you sir- at one point in my life I did make a living wiring car stereos....
Hey Mitch-
just google "gm delphi weatherpack crimper tool" they are from $20 to well over $200
For the inside of the car- these are a little bigger - the other thing I like is you can find the LED fuse that lights when it's blown- SAVES a ton of time troubleshooting!!!
Replaced my fusebox with three of them-AND move it so I can actually get to it!!!
And the old craftsman box- is now a subpanel for the rear of my car- mounted in the storage compartment
If you want to really make the next troubleshooting be a breeze- I recommend the $80 I spent on a DYMO labeler- Rhino 4200- prints on HEAT SHRINK!!!
Old Oct 17, 2019 | 01:22 AM
mitch.1972vette
Thanks so much. My health has been in the tank and I haven't been able to touch my Vette. Pancreatitis is horrible! To die would almost be a relief at this point. Your advice has been wonderful and very much appreciated. I want to use the 280's and I'm trying to get my best deal. If you have suggestions please offer me a link. I'm gearing up for my last HooRah...If it goes the way I'm planning, I will get my electrical including my headlight actuators from Richard completed. Thanks so much in advance for any help you might be able to offer.
Old Oct 17, 2019 | 04:10 AM
Gunfighter13's Avatar
Gunfighter13
In there.....
Old Oct 17, 2019 | 08:34 PM
Richard454's Avatar
Richard454
Hey Mitch-
Man- so sorry to hear about the health issues- I thought you had kicked it. Will be thinking of you.
Here's some links for the littlefuse customizable panels-
I buy my stuff from Waytek- they are great to deal with.
They have the parts broken out- so it's sort of an al a carte menu- but cheaper than the complete ones sold on eBay.
small one-
https://www.waytekwire.com/products?pSearch=hwb18
bigger one-
https://www.waytekwire.com/products?pSearch=hwb60
Relays and connectors
https://www.waytekwire.com/products?...h=280%20relays
Hope that helps-
Richard
Old Nov 22, 2020 | 09:27 PM
Kacyc3's Avatar
Kacyc3
Any update on using these for your project? Preference on diode or resistor relays?
Old Nov 23, 2020 | 12:14 PM
7T1vette's Avatar
7T1vette
Old post. You might want to send a P.M. to whom you were addressing your question.
To Auxiliary Fuse Blocks
