110 or 112 lsa
Old Jan 13, 2020 | 07:24 PM
7t9l82's Avatar
7t9l82
Default 110 or 112 lsa
talking to my cam grinder about a replacement for my L-82 cam. he thinks it may be safer from the engine vacum aspect to do a 112 lsa to play nice with power brakes and headlights. were right at 10-1 compression were talking 280 ish duration and .500 lift. his thought is with the 1.6 rockers i have with 112 lsa i won't gain much but 110 would allow a bit more horsepower. any thoughts? please none of this roller cam is better stuff. these guys grind high quality cams that I've used several times in over 40 years. otherwise i will stay with what i have. thanks for any intelligent input.
Old Jan 13, 2020 | 08:10 PM
diehrd's Avatar
diehrd
112 is fine from memory a stock L82 was 114 .
Old Jan 13, 2020 | 08:18 PM
7t9l82's Avatar
7t9l82
He was saying 110 would help out more but thought the vacuum may not be there
Old Jan 13, 2020 | 10:08 PM
diehrd's Avatar
diehrd
He is correct and giving you good advice the hp you lose will amount to nothing noticeable ..
Old Jan 13, 2020 | 10:14 PM
7t9l82's Avatar
7t9l82
I may just leave what I have it runs killer with what I've done. If I thought I'd be ok with the power brakes and headlights with the 110 lsa I'd do it but vacum cans are a pain.
Old Jan 14, 2020 | 07:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What is the spec of the cam? I doubt you would see much difference either way......splitting hairs.
All of my vacuum stuff works with 11 inches of vacuum.......the trick is making sure every line is sealed.
Jebby
Old Jan 14, 2020 | 08:29 AM
7t9l82's Avatar
7t9l82
Thanks guys that confirms what I thought and the cam grinder said.
Old Jan 14, 2020 | 09:37 AM
gkull's Avatar
gkull
My experience with hotter H-flat tappet cams was that the brakes always worked fine, but the head lights became super lazy. When you turned on the lights only one head light would slowly pop up and the other would come up until I was down the street. I considered a vacuum pump, but just lived with it for years. DCR calculators are not a perfect science. They do get you into the ball park of what duration fits in with any given static compression ratio.
A fun thing to do and it only is the cost of few gaskets and some man hours is to just change the keyway on the timing set and dial in 4 degrees or even just two degrees of advance on your existing cam.
Old Jan 14, 2020 | 11:09 AM
HeadsU.P.'s Avatar
HeadsU.P.
For what its worth, this is from a dyno test engine at Bruele' West Tech, SBC. Of course every engine & cam will be different, but this will give you a general idea.
Lobe Separation Angles, compare.
Narrow: 101 - 108
Wide: 114 - 120
In the middle: 110 - 112
Test engine vacuum:
LSA 101 = 9.8 inches of Vac
LSA 107 = 12.2" of vac
LSA 113 = 14.4"
I suppose you could fill in the blanks guestimating a LSA of 110.
I only have 11-12" of vac with a 110 LSA. I don't worry about the lazy headlights. Have brakes, have vac advance. What more do you need?
Old Jan 14, 2020 | 02:20 PM
7t9l82's Avatar
7t9l82
Well that's the kind of reassurance I was looking for. I feel a bit better with the 110 Lsa what I have now can really use more cam and that's what my cam guy was saying. Go big or go home, but don't be stupid.i don't drive much at night and if I did it wouldn't be the first time I had to get out and open the headlight door, who hasn't done that? Looks like that ,2800 convertor will work out well.
Old Jan 14, 2020 | 02:44 PM
7t9l82's Avatar
7t9l82
I advanced the stock cam 4 degrees and added 1.6 rockers when I put the pro comp 190 heads on it with the serdi 5 angle valve job and back cut valves about 6 years ago. It hits pretty hard the way it is . And it's fun telling people it's the stock cam. Most don't believe it.
Old Jan 15, 2020 | 09:38 AM
HeadsU.P.'s Avatar
HeadsU.P.
I would bet a cheeseburger, fries and a cold one, that your cam already had four degrees advance. So now, you are at eight.
Its very common for cam companies to build in four degrees advance to give the engine that down-low-grunt. That's what 99% of "street / strip" customers want.
They want instant gratification of their new purchase and they want that extra grunt where the engine operates the most: 1000-4,000 RPMs.
So, with eight degrees advance and 1.6 rockers, I would be slightly concerned about piston / Intake valve, kiss of death.
Old Jan 15, 2020 | 09:51 AM
7t9l82's Avatar
7t9l82
The cam that is currently in the car is the factory L-82 cam. So it isn't 8 degrees advanced.
Old Jan 15, 2020 | 10:39 AM
HeadsU.P.'s Avatar
HeadsU.P.
With a little research, all I could find was that the L82 cam had a centerline of 110*. And a lobe separation angle of 114*.
I could be wrong but I believe that means four degrees of advance GM built-in from stock. (Take the LSA and subtract cntr line, 114 minus 110= 4*)
So, the stock 4* + your added 4* = 8* total.
But hey, its your car. Do what you want. Lots of people have done that. The RPM power band drops off early is all.
Old Jan 15, 2020 | 12:52 PM
jackson's Avatar
jackson
Default comparo OE iron Vortec L31 LSA = 111*
FWIW as a comparison
OE iron Vortec L31 350ci LSA = 111* (FYI: that OE cam has Plenty of vacuum for brakes).
Specs for Melling replacement cam (M1320) for above is .414/.428, 191*/194*, 261*/263*, ICL 106*, ECL 116*, LSA 111*
Specs for Melling replacement cam (22210) for OEM 3896962
.450/.460 224*/224*, 291*/287*, ICL 114*, ECL 114*, LSA 114*
IO -3* BTC, IC 47* ABC
XO 46* BBC, XC -2* ABC
**Melling cat 010118-1 c2018
Old Jan 15, 2020 | 01:39 PM
7t9l82's Avatar
7t9l82
Been running that way for 6 years. Also it depends how your figuring by crank degrees or cam degrees
Pulls good till 5500, don't usually rev it past that.
Old Jan 15, 2020 | 02:13 PM
jackson's Avatar
jackson
FWIW
Manufacturer grinds CenterLInes where it wants and user can advance or retard install where he wants.
Manufacturer grinds Centerlines where it wants and that determines how much separation angle LSA is between the two.
User cannot change LSA (or overlap); It's ground in. If you can change your LSA, you must have one helluva grip to match that big chip.
To 110 or 112 lsa
Old Jan 15, 2020 | 02:44 PM
7t9l82's Avatar
7t9l82
That isn't what was implied at all. I know how a cam is measured. This started as a simple question.
Old Jan 15, 2020 | 03:04 PM
jackson's Avatar
jackson
I was not addressing any one specific individual
Old Jan 15, 2020 | 03:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by jackson
FWIW
No body said anything about altering the LSA.
I was simply stating that most "street cams" have four degrees advance built in / ground in. This advance in valve timing gives the car that off-idle, gobs of torque that most customers want on the street, but few want on the full time drag strip.
So when you dial-in a cam a additional four degrees by moving the crank sprocket to a different slot, you more than likely now have eight degrees advance.
If you want a screamer that seldom runs below 5,000, then you retard the cam or set it up at zero. The power band is then moved from 5,000 - 8,000 for example.
