Just how much work is it to remove the body?
I here of people doing body lifts talking as though it were the same as removing the engine, which I doubt, so can anyone tell me what you have to do before you actually lift the body? Just how much do you have to remove or disconnect? :confused: :cheers: :cheers:
Re: Just how much work is it to remove the body? (Graemeinvette)
You have to make sure everything is disconnected, and remove some things. I just did mine and it wasn't all that bad, easier than I thought. Nolan Adams has a booklet out for like $9.99 that lists everything you need to do, you can buy a video with it too for, I think $20 more. I think its worth it to take the body off because you see things that you can't see with it on and THEN you get the "well, while I am there syndrome"!
[Modified by mpro72vette, 7:49 AM 11/26/2002]
