Timing Light
Old Nov 7, 2021 | 05:00 AM
Alex66's Avatar
Alex66
A liitle bit late, but Innova! Very good timing light, I use it too.
Old Nov 7, 2021 | 01:32 PM
7T1vette's Avatar
7T1vette
If your mechanical advance is "all in" by 2200 rpm, you need to install HEAVIER springs, not lighter. Heavier springs will delay ignition advance so you can be "all in" between 2600-3000 rpm. Advance at that point (where mechanical advance will NOT increase with higher rpm) should be at 34 degrees BTDC.
