Dufus, Bubba's cousin installed this rear main.
Senior Member since 1492
Dufus, Bubba's cousin installed this rear main seal.
Check these pics please, is the rear main seal installed correctly? I know the pics are a little blurry but I wanted to get as close as I could. I think it's back ****-wards! :confused:
Looking from the front
Looking from the back
:confused: :confused: :smash: :smash:
:skep:
[Modified by 1970 Stingray, 4:19 PM 1/4/2003]
:skep:
Re: Dufus, Bubba's cousin installed this rear main seal. (yellow 72)
Hey! It was his first attempt at a rear seal. :D There was a 50-50 chance & I picked the wrong one! :D
Re: Dufus, Bubba's cousin installed this rear main seal. (1970 Stingray)
NO question the lip is wrong....thing is, the backing rubber section seems to look as if it fits correctly, in preferance to it being turned around.....
have to see it the other way....allmost strikes me as if the seal is not made right.....
GENE
GENE
Re: Dufus, Bubba's cousin installed this rear main seal. (mrvette)
Yup, the lip should face towards the block. This one is installed wrong. If you install a new one, rotate the seals so that the seam where the 2 halves meet up don't align with the cap and block seam.
As for the thicker part of the seal being on the inside of the block here (and outside if it's correctly installed), they're all like that. The side w/ the lip is thinner than the other side.
Marck
[Modified by Twin_Turbo, 4:26 PM 1/4/2003]
Marck
Re: Dufus, Bubba's cousin installed this rear main seal. (patsnitrovette)
Better Check closely, Dufus may hav installed one half correctly and the other half wrong. :crazy: :smash: :crazy: :smash:
BTW Did it seal?
John
BTW Did it seal?
John
Re: Dufus, Bubba's cousin installed this rear main seal. (theandies)
BTW Did it seal?
John
BTW Did it seal?
John
