Idler pin taper
Old May 4, 2023 | 02:56 PM
Chassis74's Avatar
Chassis74
Default Idler pin taper
The math is not coming out to an exact whole number and I have a hard time believing GM made a 3.2 degree taper for the idler arm. Does anyone happen to know for sure what the taper degree (idler) is? Also for what its worth the pitman arm side isn't the same taper as the idler. If you take the pin off the center link and put pitman arm pin into the idler side it will not mate tight like the pitman arm, it will rock as the taper is not the exact same. I was just curious and had to see if they were the same. Maybe its is a weird taper number.....?
Old May 4, 2023 | 03:27 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
it must be wrong one.
has to match orig 100 perc
Old May 4, 2023 | 05:44 PM
drwet's Avatar
drwet
OK. I'll bite. Why do you need to know? I have fabricated parts to fit tapered fittings - in my case ***** joints, but that was for custom setups. We can still buy parts for a C3. What are you making?
Old May 4, 2023 | 06:19 PM
Mooser's Avatar
Mooser
More often than not those types of tapers are called in inch/foot rather than degrees so it may not be an odd number
(1.500" / foot taper for idler arm is what I just saw for chevelle)
M
Old May 5, 2023 | 06:54 AM
Chassis74's Avatar
Chassis74
A new Centerlink.
Old May 5, 2023 | 06:55 AM
Chassis74's Avatar
Chassis74
M
Yes, I have seen the same info on that. Thanks
To Idler pin taper
