Brake pedal
Old Nov 9, 2024 | 03:58 PM
Jerry69's Avatar
Jerry69
2nd Gear
Default Brake pedal
I have a 79 corvette. It just started having a hard brake pedal when first started. Like the power brakes are not working. After it runs for about 15 minutes it is fine, just like normal power brakes. I pulled the vacuum hose off of the booster with the engine running and it has plenty of vacuum. Any ideas what is causing this?
Old Nov 9, 2024 | 04:24 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Test the check valve perhaps. If it were a torn diaphragm it wouldn't come good. Test the booster for leaks as well. Will it hold a vacuum?
Old Nov 9, 2024 | 06:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
Jerry,
Is the booster vacuum line dedicated? In other words, a solo line all by itself from base of the carb to the booster?
I have seen some booster lines T-off to other accessories. With that scenario the vacuum varies at the booster causing issues.
To Brake pedal
