Weird front wheel rotational knock
Old Jan 1, 2025 | 02:25 PM
Uniquemicro's Avatar
Uniquemicro
Default Weird front wheel rotational knock
1980 L48 auto here. I removed both tires during a header install and replaced the steering box and upper steering column bearing while I was at it.
Yesterday when I put the tires on and started down the road I heard a knock from the front that was proportional to speed- knock knock knock... Then after checking and not really seeing anything I brought the car up to speed and dont hear it anymore. What could it have been? Bearings? Brakes are good.
TIA,
Ken
Old Jan 1, 2025 | 08:51 PM
REELAV8R's Avatar
REELAV8R
Maybe a wheel wasn't seated correctly and was cocked on the hub centric section when you tightened the lugs, then centered itself after a bit. If that is the case you now have loose lugs on that wheel.
Old Jan 1, 2025 | 09:49 PM
Uniquemicro
thanks. i will check
Old Jan 1, 2025 | 09:59 PM
OMF's Avatar
OMF
Could also be wheel weights hitting the caliper......
Old Jan 2, 2025 | 01:21 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
pull the wheel and look for the shiny spot that was hitting...
Old Jan 2, 2025 | 06:41 PM
forman's Avatar
forman
Could be the brake pads centering
Old Jan 3, 2025 | 06:11 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think it the knock of death. It goes knock knock from the front wheel, then goes silent. Then the whole car self destructs !
Or maybe not.
Old Jan 3, 2025 | 08:11 AM
Rescue Rogers
Could be the noise you hear just before a wheel locks up....pull it apart and check it out before driving it again. Its not a fun experience
To Weird front wheel rotational knock
