What size BFGs
Old May 18, 2003 | 07:27 PM
QuickVet's Avatar
QuickVet
Default What size BFGs
What size drag radials are you guys using on your stock 15X8 rims?
What are your best 60' times with em and what pressure are you using?
Old May 18, 2003 | 07:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: What size BFGs (QuickVet)
I had 275/60/R15 (not drag radials tho)
Old May 18, 2003 | 10:00 PM
QuickVet's Avatar
QuickVet
Default Re: What size BFGs (Twin_Turbo)
i dont know if they make that exact size in the drag radials. i will have to check.
Old May 18, 2003 | 10:12 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I use the same size Drag Radials on my set of 15x8 inch TT2's...
Old May 19, 2003 | 12:55 AM
stalker's Avatar
stalker
275/60-15, 1.80 60ft, 25psi
:cool:
[Modified by stalker, 7:56 PM 5/18/2003]
Old May 24, 2003 | 01:12 PM
QuickVet's Avatar
QuickVet
Default Re: What size BFGs (stalker)
I think im going to try those for my next set of tires :yesnod:
Old May 24, 2003 | 01:15 PM
79Corvette02's Avatar
79Corvette02
Hey Stalker-are thems steel wheels? They look badass w/ the black face of the tire and the dark colored car...Maybe I ought to try some steelies out back with some drag radials when I take the car (finally...) to the strip.
Old May 24, 2003 | 01:42 PM
tshort's Avatar
tshort
CI 7-8 Veteran
STALKER - Your setup looks damn cool. We should call you Shaft :cool:
Old May 24, 2003 | 05:23 PM
Gordonm's Avatar
Gordonm
Default Re: What size BFGs (tshort)
Just a thought the 275 60 15 give you an 8.8 inch tread width with a section width of 11.1 and a dia of 28 inches. The 275 50 15 give you a 10 inch tread and a section of 11.3 but a 26.1 diameter. The 50 series gives you more contact with the track and a little shorter for more gear ratio. the section width is about the same so neither should rub. If I was going to use them for the track mainly I would go with the 275 50 15s. Seems like you should get more bit and a little better gear ratio.
Old May 24, 2003 | 05:28 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: What size BFGs (Gordonm)
like gordon said aaron,what size rear tires do you have now?the 275/60's like i have are 28 inch tall,they give me more mph but less gear for off the line,if your looking to give up some gear then go for it,but if not then 255/60 might be better.another rain out for the challenge,is the rain ever gonna stop.
To What size BFGs
