Ignition Wire Looms
Old Jun 4, 2003 | 11:10 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Default Ignition Wire Looms
Any one have pics/recommendations for what to do for wire looms? I was going to try and reuse the original equipment setup with the chrome covers etc and I think I've decided to look at other options. This is for my new 383, if you have an idea let me know where I can buy the stuff if possible :cheers:
Old Jun 4, 2003 | 11:37 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Ignition Wire Looms (69shark)
I have the R&M looms, they are for 8mm wires but I drilled out the holders to 8.5 on a drill press. They look nice and keep the wires organized. Most hot rod shops carry them, also JEG's & Summit have them.
Old Jun 4, 2003 | 11:48 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Here's a pic of my setup:
Old Jun 5, 2003 | 12:17 AM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Re: Ignition Wire Looms (C3 Shark Tank)
C3 Shark Tank...
That is clean looking. Kudos!
Old Jun 5, 2003 | 12:42 AM
OkeeGuy's Avatar
OkeeGuy
i also have R&M and luv em...
VERY good quality and i think they look outstanding...
Old Jun 5, 2003 | 04:10 AM
442olds's Avatar
442olds
This is a pic of what we did on my buddie's 383 in his monte, I like to keep the wires as short as possible and up and away from any header heat.
Now on my big block in the vette I uses MSD 8.5mm wire and their new Pro Clamp wire seperators (summit part number msd-8843, still on backorder). Again short wires directed away from heat and very minimal bending, I try to stay away from sharp bends in the wire as this creates yet another spot where the wire will crack prematurely due to heat and stress. My 93 z28 is a good example of the worst possible situation for spark plug wire routing.
Old Jun 5, 2003 | 10:06 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Ignition Wire Looms (SIGNGUY)
I used the R&M also. I am happy with them at this point.
Old Jun 5, 2003 | 12:25 PM
Stewart's74's Avatar
Stewart's74
Default Re: Ignition Wire Looms (Eddie 70)
Moroso here
Old Jun 5, 2003 | 12:29 PM
Fevre's Avatar
Fevre
Ones I got too! :thumbs:
Old Jun 5, 2003 | 01:08 PM
PRNDL's Avatar
PRNDL
SIGNGUY, are you using the same brand hose protector I use? Mine is Campbells hearty chicken! :lol: MJ
Old Jun 5, 2003 | 03:06 PM
69shark's Avatar
69shark
Cruise-In I Veteran
Default Re: Ignition Wire Looms (Fevre)
Anybody have the part# or manufacturer of these R&M? I can't find anything on Summit :confused:
Old Jun 5, 2003 | 03:12 PM
Fevre's Avatar
Fevre
http://store.summitracing.com/partde...rt=RNM%2D1101P
Old Jun 5, 2003 | 06:36 PM
C3 Shark Tank
Default Re: Ignition Wire Looms (bgrice)
C3 Shark Tank...
:thumbs: Thanks! to say I'm an **** retentive neat freak is a bit of understatement :lol:
Old Jun 5, 2003 | 08:47 PM
Red73's Avatar
Red73
[Modified by Red73, 9:00 PM 6/5/2003]
Old Jun 5, 2003 | 09:25 PM
69shark's Avatar
69shark
Cruise-In I Veteran
Default Re: Ignition Wire Looms (Red73)
Well, I couldn't get the R&M intime from Summit and I wa stalking to the guys at the shop that built my engine and they had the same as Red73's , so now I can build the wires. Thanks all:cheers: :cheers: :cheers:
Old Jun 5, 2003 | 09:41 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: (MNJack)
i dont get it?????????
Old Jun 5, 2003 | 11:16 PM
PRNDL's Avatar
PRNDL
Default Re: (SIGNGUY)
Your pic is a little fuzzy, but do you have some kind of shield protecting a hose from coming in contact with your passenger-side header? (directly above the cap labeled "engine collant only") I have a soup can on my upper radiator hose performing a similar function. MJ
Old Jun 5, 2003 | 11:43 PM
74BBcherryred's Avatar
74BBcherryred
R&M all the way ,you won't be sorry :thumbs:
To Ignition Wire Looms
