Anyone bend their own exhaust?
Re: Anyone bend their own exhaust? (dath)
dath those benders will not work. They are for heavy wall pipe. Forget it. I have that bender at the shop for roll cages. We have tried exhaust and it doesn't work.
You can easily buy 45's , 90's and lengths of pipe from summit or any number of places. Buy the parts and weld it up. You can adjust the angles as needed. Properly welded and it will look one piece and fit tight.
Re: Anyone bend their own exhaust? (norvalwilhelm)
Here was my do-it-yourself exhaust idea. Didn't generate much interest here on the forum but one day I would like to give it a try.
[Idea] Mandrel Bent, Stainless Steel Exhaust System. Do It Yourself. CHEAP!? http://forums.corvetteforum.com/zerothread?id=386032
So those pipe benders don't work... or do they?
Here is what appears to be the same 16 ton model for quite a bit less...
http://www.thetoolmansshed.com/product.asp?3=437
edit....might not be cheaper after including hefty shipping costs!!!
I need 2 fairly short lengths of pipe with a sharp bend to connect my headers to the rear exhaust pipe. Currently have some flexpipe connecting them.. :(
MJ
like these things, which I would buy, except I dont think they bend enuf...
[Modified by MNJack, 11:39 PM 6/17/2003]
[Modified by MNJack, 1:06 PM 6/18/2003]
MJ
Re: (MNJack)
MJ
MJ
Shoot - Wish I had a picture of those installed - they work great
Re: Anyone bend their own exhaust? (PatG)
Thanks for the input on this. I was wondering if they would work or not. So what type of equipment is needed to bend thinwall pipe? I'll most likely find a source for pre-bent anyway.
-Justin
Hrm... Okay, so perhaps I should just give in and buy the bent pieces and cut and weld them all up... So when cutting them, do you recommend expanding them and then welding, or do you just butt weld them? If you butt weld, how do you ensure all of the angles match up well (what do you cut the pipe with I guess is the question)?
dath I cut all my cuts with a chop saw. I bute weld everything with a tig welder but with steel a mig welder would work. Stick would not do a good job.
I have an assortment of 90's and 45's on hand and cut and splice them into an exhaust. You start right out of the headers adding pieces together, tacking , checking and keep on building. It only invoves 2 good angles at the muffler plus a few joints along the pipe.
In my pipes there are 3 angels per side, everything is stainless so it doesn't rust and after a good weld looks almost one piece but fits better then one piece.
I agree with Norval, just buy the bends and build a system without a bender. Put the $200 from the bender toward a welder. IMO, for the price that you'll pay somebody else to build and install your system, you can get the raw materials and a small home welder.
A few years ago, I bought a small Lincoln 110v wire feed welder with a mig kit (gas) and the thing works great for exhaust. I think I paid around $400 for everything. Without a doubt, it's one of the best tool investments I've ever made. Once you have a welder, you'll wonder why you went so long without one.
Re: Anyone bend their own exhaust? (Flareside)
I still have an the urge to try one of those benders on exhaust, but I respect Norval's opinion as he's been right in the past :D
