u joint mayhem
Old Jul 8, 2003 | 06:04 PM
adjada's Avatar
adjada
Cruising
Default u joint mayhem
whaa right rear u joint let go broke an ear off differential housing can one be fabricated and welded on or am i looking for a new rear thanks for the help in advance 72 convert. small block
Old Jul 8, 2003 | 06:14 PM
killain's Avatar
killain
Oldtimer
Default Re: u joint mayhem (adjada)
You could more than likely reweld a tab onto the rear, BUT you'd more than likely will need to remove the rear and there's a good chance it needs to be degreased which by the time you get done you might as well changed the rear end casing. :cry
