B & M shifter
Old Aug 5, 2003 | 05:59 PM
machineg's Avatar
machineg
Default B & M shifter
I'm new,,,, So hello all you corvette people. I have a 1981 red convert.
I have just replace the interior and dash. I'm looking for a B & M shifter for my automatic. Also, I'm looking for advice on Headers. Thanks for your time
Old Aug 5, 2003 | 06:45 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: B & M shifter (machineg)
Welcome to the Forum. :seeya
Old Aug 5, 2003 | 07:33 PM
Alwyn678's Avatar
Alwyn678
:seeya Check out Dynomax headers from summit..........As for the shifter I am not sure....If you want a shift kit then check out the Transgo shift improver kit
BTW the Dynomax is ceramic coated fit perfect and are just a shade over 200 bucks..Make sure you get some Percy's aluminum gaskets to seal them :yesnod:
[Modified by Alwyn678, 9:58 AM 8/6/2003]
Old Aug 5, 2003 | 07:48 PM
Rick68's Avatar
Rick68
Welcome :cheers: I had a B&M Quick Silver shifter in a older Firebird and I loved it. I teamed it up with a B&M 3000 stall torque converter and B&M shift kit and it was amazing. I know one of the guys on the forum put this shifter in his vette so hopefully he will let you know how he likes it.
Old Aug 6, 2003 | 12:26 AM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Default Re: B & M shifter (73Stingraycoupe)
Welcome to the forum :cheers: ..As for the shifter I had a B+M megashifter in a Camaro for a while,biggest piece of junk I ever owned.The tiny B+M cables broke three times in a year,and occasionaly the ratchet mechanism wouldnt operate or would hang up.I replaced it with a Hurst Quarterstick,they use a much better cable and never had a failure of any sort with it.
Old Aug 6, 2003 | 08:55 AM
The Money Pit's Avatar
The Money Pit
I just put a Megashifter in my 80,quite a bit of custom work,but is possible.Had to make a console plate and rework the shifter mounting a bit.
As for headers,go with Hookers.From what I've seen at the shows the fit is the best.Mine slid right on with no massaging what so ever. :smash:
To B & M shifter
