Catalytic Converter modification
Old Sep 13, 2003 | 03:04 PM
VETJET's Avatar
VETJET
Default Catalytic Converter modification
Has anyone modified their catalytic converter by putting a staright pipe inside the converter. I am wanting to eliminate the restiction of the converter but maintain the factory look. and of course I plan to use the vehicle of off road use only.
Old Sep 13, 2003 | 05:20 PM
MIKER's Avatar
MIKER
Default Re: Catalytic Converter modification (VETJET)
It's a good thing you said "off road use only"! Otherwise you might have been subjected to a cyber beating from the very vocal, minority population of politically correct members on this forum. :cry
I once performed this conversion for "off road use only" to a cat for a '95 Z28. It worked out well. On this particular catalytic converter, a 3" pipe fit perfectly inside after removing the catalyst brick. I used a wire feed welder to secure the pipe.
Happy offroading VETJET :thumbs:
Old Sep 14, 2003 | 03:51 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Catalytic Converter modification (MIKER)
I modified mine, it's now hollow. ( no emissions here ) But I should have installed a pipe into it. Someone told me without the pipe it causes turbulence.
Old Sep 14, 2003 | 06:37 AM
RJR99SS's Avatar
RJR99SS
Default Re: Catalytic Converter modification (Desertdawg)
a gutted out cat converter is also very loud. All the turbulance going on inside the chamber can be heard inside the car.
Old Sep 14, 2003 | 07:54 AM
Disco_Mike's Avatar
Disco_Mike
I had an 88 S10 pickup that the cat modified itself. The plug rusted out and I dumped a half a million ceramic beads on the road. Once I put in the replacement plug, I didnt notice any change in sound.
To Catalytic Converter modification
