Back-uo lights not functioning
Old Oct 1, 2003 | 04:38 PM
Clown Puncher's Avatar
Clown Puncher
Default Back-up lights not functioning
To begin with I am a Novice. The Backup ;ights do not come on when I am in reverse. The previous owner said that he thought they had come on in the past. This is a 71. I checked the fuse, which is also the turn signal fuse, and know that it is good. I replaced the bulbs, and still nothing. Is it more probable to be a transmission issue? By the way it is a three speed automatic. Could it be something else?
Thanks :confused: :chevy
[Modified by Clown Puncher, 3:44 PM 10/1/2003]
Old Oct 1, 2003 | 04:57 PM
gmcclurg's Avatar
gmcclurg
Default Re: Back-up lights not functioning (Clown Puncher)
I think my 77 automatic has a neutral switch in the console that also controls the back up lights. I am not sure about 71.
Old Oct 1, 2003 | 05:10 PM
Simul8's Avatar
Simul8
I also have a 71 with a 4sp. The backup switch is located on the left side of the tranny and is connected to the shifter linkage by a small rod. There are two wires connected (I believe a green & a pink wire ). The wires go up the left-center firewall to a connector. The connector is shaped like a batwing.
Hope this is some help.
Old Oct 2, 2003 | 11:49 AM
Clown Puncher
Thanks Guys. I will try the suggestions. :thumbs:
Old Oct 2, 2003 | 01:34 PM
Missileman's Avatar
Missileman
On a 71 with TH 400 the backup lights are activated by a combination neutral safety/backup switch on the shifter. Remove the shifter ball and the four screws holding the shifter cover plate. The switch is visible attached to the right side of the shifter base. Using a voltmeter check voltage across the wires on the switch (not the purple ones-those are neutral safety) in all positions of the shifter (P,R,N,D). This will tell you exactly where the problem is.
New switches come form many vendors for about $60. Hope this helps.
Old Oct 2, 2003 | 02:08 PM
Edzred72's Avatar
Edzred72
The three speed automatic has the back up light switch wireing incorporatd into the neutral safety switch in the center counsole. The switch itself is connected to the shift lever. If all looks good there, (no breaks) start checking the ground connections (blk wire) at each light housing in the rear. Continuity of the light bulb wires in the rear lighting harness would be next, to be sure they are not broken. I believe it's 1 green wire that runs from the neutral safety all the way back to each rear light housing. I just finished troubleshooting my back up lights...and found the conversion from Auto trans to manual was not completed by the previous owner. I converted the auto back up switch to a trans mounted switch. PITA!!!
Good Luck
Eddie
WOOPS...Missle Man beat me to it.. :D
[Modified by Silvr77, 1:10 PM 10/2/2003]
Old Oct 2, 2003 | 04:18 PM
goofygrin's Avatar
goofygrin
Default Re: Back-up lights not functioning (Silvr77)
For people with manuals (like me), there is a two wire connector on the tranny on the passenger side (which in my case always falls off!!!).
To Back-uo lights not functioning
