Wanted: Loud Mufflers
Old Oct 22, 2003 | 09:43 PM
MRKearney's Avatar
MRKearney
Default Wanted: Loud Mufflers
Can anyone recommend a muffler that will cause people to take notice when they hear my 1980 Corvette coming down the road?
Old Oct 22, 2003 | 09:55 PM
VETDRMS's Avatar
VETDRMS
Default Re: Wanted: Loud Mufflers (MRKearney)
Dynomax Bullets will do that. :yesnod:
:cheers:
Old Oct 22, 2003 | 09:58 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Wanted: Loud Mufflers (VETDRMS)
:lurk: i need to know as well
Old Oct 22, 2003 | 10:06 PM
L-82kid's Avatar
L-82kid
Default Re: Wanted: Loud Mufflers (Metal Wulf)
Run headers, 2.5" mendrel bent pipes without H-pipe, and 40series original flowmasters.
Old Oct 22, 2003 | 10:17 PM
LFZ's Avatar
LFZ
2 words....SIDE PIPES!
Old Oct 22, 2003 | 10:38 PM
hudman's Avatar
hudman
Default Re: Wanted: Loud Mufflers (Redshark6974)
I am running 2.5 inch pipes without the H pipe into 40's and it ain't loud enough!
Find another solution.
Old Oct 22, 2003 | 10:48 PM
FERL 73's Avatar
FERL 73
Magna Flow. More canoochies than FM's.
Old Oct 22, 2003 | 10:53 PM
PRESSURERAT's Avatar
PRESSURERAT
Mufflers? What are those?
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
CHAMBERED!!! :yesnod: :cheers:
Old Oct 22, 2003 | 11:33 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Default Re: Wanted: Loud Mufflers (DP77Vette)
Moroso Spiral Flows, they just pretend to be mufflers. :D
[Modified by Rolling Thunder, 10:33 PM 10/22/2003]
Old Oct 23, 2003 | 12:46 AM
Rottenrob's Avatar
Rottenrob
Default Re: Wanted: Loud Mufflers (FERL 73)
I set off car alarms, before I installed my H-pipe... best flow as well. :iagree: :yesnod:
Old Oct 23, 2003 | 01:43 AM
madvette74's Avatar
madvette74
HOOKER SUPER COMP!!
Old Oct 23, 2003 | 02:07 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Wanted: Loud Mufflers (madvette74)
Sidepipes would definitely be the method of choice, but if you want mufflers, and if you want extremely cheap, KBD Targas, (sold under a few different names/brands) worked great for me. Basically open tubes with some damping area around the outside. See the muffler section of most Vette part Dealers.
The 4 upward-pointing chrome tips are great :D
Old Oct 23, 2003 | 02:18 AM
aharte's Avatar
aharte
My supertrapps are loud. Scaled up motorcycle "mufflers."
Old Oct 23, 2003 | 08:37 AM
Brettmc's Avatar
Brettmc
:cheers:
:iagree: I run these mufflers. When the wife told me she could hear me coming from a mile away, I knew I scored the right ones. They don't have the interior resonance that the Flows do. Also, every hotrodder and his granny have Flows. It's nice to hear non-Flowmaster exhaust....be different...
Brett :thumbs:
Old Oct 23, 2003 | 10:08 AM
TedH's Avatar
TedH
I get compliments on the sound of my car. It rumbles at idle and howls under WOT:
Jet-Hot Heddman headers
2.5" aluminized - custom bent system
2.5" H-pipe just aft of the trans x-member
Dynomax Super Turbos
No regrets.
Old Oct 23, 2003 | 10:44 AM
bhmyers's Avatar
bhmyers
:iagree:
Same setup I have.
To Wanted: Loud Mufflers
Old Oct 23, 2003 | 10:55 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Wanted: Loud Mufflers (TedH)
No regrets.
super turbos aren't loud at all :nonod:
Old Oct 23, 2003 | 12:38 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have Magnaflow SS and they are not too bad at idle and cruise in 4th but wide open at 5500RPM on a chassis dyno I almost put my fingers in my ears.... but you know I wouldn't do that
Oh yeah you can roll a golf ball right thru these babies.:lol:
[Modified by MotorHead, 8:03 PM 10/23/2003]
Old Oct 23, 2003 | 01:03 PM
gkull's Avatar
gkull
Default Re: Wanted: Loud Mufflers (MotorHead)
Vortec stainless steel packed 3 inch in and out. It's a welded box type race muffler that your can see light through. Sold at Mienike mufflers for about $130 each.
I ended up installing a 3 inch diameter ovalled H pipe near the diff to make it somewhat quieter. at idle and cruise they are OK, but at WOT they can be heard from a long way away.
