timing
Old Nov 18, 2003 | 08:45 PM
ITSovr4U's Avatar
ITSovr4U
Default timing
If you add timing at an idle does it add to your total timing or is total timing controlled by the weights and will only advance as much as they allow. My car seems to only run strong with alot of timing at idle like 32 degrees and i did not check total timing after i advanced the distibutor. So that is why i cant answer my own Q. Thanks for your help. If someone would like to explain exactly how the distributor works I would love to know. Thanks, JOHN
Old Nov 18, 2003 | 09:01 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: timing (ITSovr4U)
https://www.corvetteforum.com/techti...=109&TopicID=3
