Ignition Wiring?
Old Jan 22, 2004 | 10:03 AM
Apocolips's Avatar
Apocolips
Default Ignition Wiring?
The previous owner of my 1970 had a 305C.I. with HEI ignition installed, why I have no idea. I have removed the 305 and am getting ready to install a 350 with original ignition system. All of the wiring was changed to allow the HEI to work. I am in need of instructions on how to wire the new (original) points coil and distributor. I bought a wiring diagram that helps most of the time, but with the way the wiring has been screwed up for the HEI I need very specific instructions. Please Help!
:flag
Old Jan 22, 2004 | 10:16 AM
zwede's Avatar
zwede
Default Re: Ignition Wiring? (Apocolips)
There are 2 basic differences. The power feed wire to the coil is a regular wire for HEI and a resistor wire with points. If you don't have the resistor you will burn up the coil and points. Either get the correct wire, or an aftermarket resistor (MSD has them, for instance).
The second difference is there was a wire from the starter to the coil. This supplied full voltage during cranking to make it start easier.
The rest should be the same.
Old Jan 22, 2004 | 10:19 AM
mvftw's Avatar
mvftw
Default Re: Ignition Wiring? (zwede)
Do yourself a favor, since it's Not a NOM motor, keep it HEI. You'll be happy :crazy:
Old Jan 22, 2004 | 10:26 AM
Apocolips's Avatar
Apocolips
Default Re: Ignition Wiring? (mvftw)
I would love to keep the HEI, but I need a tach, and the original on has a tach drive.
:flag
Old Jan 22, 2004 | 11:09 AM
mvftw's Avatar
mvftw
I believe they sell HEI with tach drive
Old Jan 22, 2004 | 11:19 AM
Apocolips's Avatar
Apocolips
I know, but the price is a bit more than I can afford at this point.
:nopity
Old Jan 22, 2004 | 11:31 AM
Robert N's Avatar
Robert N
I quite like my points setup. PITA to adjust but quite reliable. After 24 years sitting, the old Accell dual points setup has run flawlessly for well over a year now. She has never failed to start in temps from 45 degress to 100+. She has sat for as long as 3 weeks.
Old Jan 22, 2004 | 12:21 PM
Barry's70LT1's Avatar
Barry's70LT1
This may be of some help .
To Ignition Wiring?
