1979 Hood Latch Issue
Old Mar 7, 2004 | 02:14 PM
jacobsed's Avatar
jacobsed
Default 1979 Hood Latch Issue
Ok, the driver's side unlatches but the passenger side won't. How can I manually unlatch it? It is driving me crazy!!! :mad
Old Mar 7, 2004 | 03:01 PM
wombvette's Avatar
wombvette
Default Re: 1979 Hood Latch Issue (jacobsed)
Just hook it with something and pull hard, but you need to replace the cable. You will find the tabs are broken.
Old Mar 7, 2004 | 03:08 PM
1979toy's Avatar
1979toy
If you look in the wiper trough you'll see a round plug behind each of the latches. Remove the plug on the side that is lotched and put a screwdriver in there to pry the latch loose with the tab designed for exactly this.
It will help if you can have another Corvette of the same year group to study before hand.
Old Mar 7, 2004 | 03:15 PM
mapman's Avatar
mapman
Some photos to help:
http://www.madvet.com/shop?frame=1.264.3852
Old Mar 7, 2004 | 04:28 PM
jacobsed's Avatar
jacobsed
Default Re: 1979 Hood Latch Issue (mapman)
Excellent....thanks guys....I'll try it later today.
Old Mar 7, 2004 | 11:06 PM
jacobsed's Avatar
jacobsed
OK, I got the latch to open! What an ordeal that was. Sure enough, the little platic cable mount that screws to the metal latch bracket busted. So the cable wasn't actuating the passenger latch.
To 1979 Hood Latch Issue
