Driveshaft Yoke Size Question
Old Aug 1, 2004 | 10:49 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Default Driveshaft Yoke Size Question
I replaced the rear in my 68 with a rear from a late 70's Vette. Both rears are the same except the 68 rear (4.11) has a 1310 series pinion yoke and the 70's rear (3.08) has a 1330 series pinion yoke. Whats up? Do I need a later driveshaft? If so, what year car?
Old Aug 1, 2004 | 12:06 PM
ram82fire's Avatar
ram82fire
There are joints available to cure your problem , find a GOOD parts dealer and you will have your problems solved !
gman
Old Aug 1, 2004 | 11:30 PM
BBShark's Avatar
BBShark
Can ayone tell me what year driveshaft has 1330 yokes?
Old Aug 2, 2004 | 08:05 AM
70BBvert's Avatar
70BBvert
I believe in 71 the driveshafts all became the larger diameter & used 1330 series u-joints. Spicer makes a solid 1310/1330 series joint.
Jim
Old Aug 2, 2004 | 10:40 AM
melissa0907's Avatar
melissa0907
I have a larger diameter yoke from a late '70s vette laying around. I ordered it for my car but it was the wrong one for my '80. As it turns out the '79 and '80 yokes are different I guess. ('80 being smaller) If you need it I could sell it for a good deal. Let me know.
Old Aug 2, 2004 | 11:40 AM
redvetracr's Avatar
redvetracr
I think the Spicer number you need is (or was) 5-134X
...redvetracr
To Driveshaft Yoke Size Question
