Roller Rocker question for ya..
Old Aug 1, 2004 | 11:03 AM
ultimix's Avatar
ultimix
Default Roller Rocker question for ya..
Just picked up some -COMP Cams Magnum Roller Tip Rockers
SMALL BLOCK CHEVY
3/8" Stud, 1.52 Ratio #1412-16
A friend said that I should have gotten the full rockers and changed the value cover to a tall. The Full rockers I wanted wouldnt fit under the stock valve cover.
He also said that I should go with the 1.6 ratio.
Here is the question. Is it worth it to go with the full roller rocker at 1.6 and change the valve cover, from the tips 1.5 I have with the stock valve cover??
If I am going to do it I want to get the best performance and do it right the first time -
Help please - thanks
Mark
Old Aug 1, 2004 | 11:16 AM
L79vette's Avatar
L79vette
I have the GM self-aligning 1.6 ratio full roller rockers under my stock valve covers. Have to use two gaskets, but it does fit.
You'll get a lot of opinions about whether there is any performance gain or not. I can't tell, because I did a few other changes at the same time. But I do know I'm getting another 30 thousandths lift at the valve, which can't hurt.
Old Aug 1, 2004 | 11:47 AM
Gordonm's Avatar
Gordonm
The only reason to go to a full roller is if spring pressure is over 300 pounds. Most of the solid and hyd flat tappet cams don't come close to this. You will gain a little HP with the 1.6 vs. 1.5 but not enough to really notice. Roller rockers are really needed for roller cams but the roller tips will work fine. I have been running them on my car for quite a while at 7000 rpm and spring pressure of 290 open and they are working great. They also fit under the stock covers. Keep the roller tips.
Old Aug 1, 2004 | 12:01 PM
ultimix's Avatar
ultimix
Here are the specs on the cam I am running -
Part Number 12-211-2
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 270H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.47 0.47
Duration At 0.006 Tappet Lift 270 270
Valve Timing At 0.006
Open Close
Intake 29 61
Exhaust 69 21
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 224 224
Lobe Lift 0.313 0.313
Lobe Separation 110
Recommended Valve Springs 981-16
Old Aug 1, 2004 | 12:10 PM
Gordonm's Avatar
Gordonm
There is no need to go to roller rockers with that cam. The 981-16 springs are quite mild springs and do not need roller rockers. I am running a .525 lift cam with my roller tips just fine. Save your money for something that will build HP.
Old Aug 1, 2004 | 12:13 PM
stingr69's Avatar
stingr69
The difference in lift is about .030" from 1.5 rockers to 1.6 ratio rockers. You can put that into DD2K and get very little performance improvement. The 1.6 ratio rockers might require head mods to fit. The 1.52's are a bolt-on that fits under stock valve covers. Full rollerized rockers are overrated and overkill for most applications.
I realy like those Comp 1.52 cast steel roller tip rockers. I recomend them for just about everything now. I run them in my 69 Z/28 and I have installed a set on my L-82 engine this week. Great rockers and the price is nice too.
-Mark.
Old Aug 1, 2004 | 09:07 PM
ultimix's Avatar
ultimix
As always -
thanks for the advice!!!
Mark
Old Aug 1, 2004 | 10:54 PM
comp's Avatar
comp
i don't know about Over rated or Over-kill but spending the $$ on other
parts is what i would do also
Old Aug 2, 2004 | 09:56 AM
migraine99's Avatar
migraine99
I have an Edelbrock 2102 cam (Intake 278°, Exhaust 288°, 5° ATDC, 29° ABDC, 44° BBDC, 10° BTDC, 112°, 107°). Will I benefit any by changing to roller tipped rockers? With my cam, should I get 1.5 or 1.6 ratio?
Any help would be greatly appreciated.
Chris
Old Aug 2, 2004 | 08:28 PM
Gordonm's Avatar
Gordonm
Chris
The benefit to going to a roller tip is a little less wear on the valve guide due to a little less loading. The big bebefit is the stock rockers usually only measure 1.46 to 1.48. Therefore you never really get the full lift the cam offers. The 1.6 will give you a little more out of your existing camso if you don't have them yet the 1.6s won't hurt.
Old Aug 2, 2004 | 10:21 PM
marshrat99's Avatar
marshrat99
I'm running the roller tip rockers you're asking about with 1.52" ratio on my 355 with CompCam's XE262 cam. No problems here with the stock valve covers.
Old Aug 3, 2004 | 05:54 AM
Fevre's Avatar
Fevre
What heads are you running? You will need guideplates for most aftermarket rockers and you will need to change out the press in studs if you have stock heads.
Old Aug 3, 2004 | 02:11 PM
L79vette's Avatar
L79vette
Will the GM self-aligning 1.6s, I have no guideplates, press-in studs, and stock valve covers. Rev limiter is set to 6600RPM. Been like this for three years, no problems, and I don't baby it.
Old Aug 3, 2004 | 02:57 PM
migraine99's Avatar
migraine99
Would you recommend the COMP Cams Magnums?
Old Aug 3, 2004 | 03:21 PM
Gordonm's Avatar
Gordonm
Yes I would. That is what is under my valve covers.
Old Aug 3, 2004 | 04:11 PM
ultimix's Avatar
ultimix
Here is what I decided to do -
I already have the comp Cams tip Rollers and I went ahead and bought the full Comp Cam Roller Magnum rocker / along with a tall valve covers. I am going to let my mechanic decide which to due and just return the unused ones. My head has been hurting on which set up to do
I will keep you posted -
Mark
Old Aug 3, 2004 | 04:16 PM
Fevre's Avatar
Fevre
What heads do you have?
To Roller Rocker question for ya..
Old Aug 3, 2004 | 08:09 PM
ultimix's Avatar
ultimix
My car was rebuilt to LT-1 Specs - so I think, notice I say, think they are they the ones that should be with an LT1. I was thinking about replacing them but my mechanic said dont, they were pretty good.
Not sure if that makes sense...new at the mechanical thing
Mark
Old Aug 3, 2004 | 09:04 PM
Gordonm's Avatar
Gordonm
Cylinder heads are the key to making HP. The LT1 heads were good back in the early 70s. By todays standards I would use them for a door stop. Mine are tucked away in the basement. You would be far better off putting money into a set of new heads than trying to make the old heads work.
Old Aug 3, 2004 | 09:08 PM
ultimix's Avatar
ultimix
What do you recommend?? for my set up..350 Auto 70
thanks
Mark
