New Engine re-build pix need help posting please
Old Aug 6, 2004 | 05:14 PM
marky mark's Avatar
marky mark
Default New Engine re-build pix are here. Thanks Bryan!
If anyone can help me to post some pix I would appreciate it. Not sure how that is done but I have the digital pix ready.
Just got car back today after a long wait. This was a comprehensive re-build including engine, tranny, new clutch, new fuel system, new headers plus a few other items that were installed or fixed that were unrelated to the drivetrain.
On the way home I noticed two things. One was a noticable vibration coming on about 2400 rpm. This is a .060 over 427 pretty much stock,etc. The vibration was in the seat of your pants. The shop that did the work is a good one and I did request the engine be balanced (will have to confirm this detail next Monday). Engine was run on their in house dyno.
Don't want to jump to conclusions but is this a symptom of an unbalanced or incorrectly balanced motor? The flywheel and harmonic I supplied came off of my 427 so I know they are correct (internal balance). The vibration is also noticable when standing still and reving motor up above 2400 rpm. It seems to be pretty consant, perhaps less vibration on up to 3500 rpm. Don't want to rev any higher right now.
So, I know it isn't the tires. I am stuck with these possibilities I guess: motor, transmission (maybe not if it does it in neutral standing still), 4 spd. which was rebuilt also, clutch/pressure plate, flywheel and harmonic balancer. I did add headers also. Old engine was as smooth as a turbine. Hope it isn't the engine. Any ideas or similar experiences?
Second problem was a fuel leak and stumble while driving. I found where the fuel leak is coming from (in pix). Not so sure on the stumble. It revved quite nicely at a stop but under load it started bucking and missing big time over about 2800 rpm. May be fuel related but the leak is coming from the return line. We installed a 6AN Aeroquip supply line from the tank to the Edelbrock mechanical pump and are using a Mallory regulator w.press set at 6 psi. Since the supply line was increased should the return line also be larger? Carb is a Quadrajet. Only thing I could think of was the mechanic had to use a smaller in line filter than I had supplied due to space considerations. Not sure if that's it or not. Any ideas?
Sorry so long, just didn't want to leave a vague note about a vibration and fuel leak.
Pix to follow soon hopefully.
Thanks in advance.
Regards, M ark
Old Aug 6, 2004 | 05:31 PM
brystheguy's Avatar
brystheguy
Find a place to host your pictures. I use photobucket.com, but there are others that are also free. Type your message and click on the little mountain picture (Insert Image) above the text box. Type in the address of your hosted picture and click OK. That's it. There is a testing forum for you to try it out from the main page.
Old Aug 6, 2004 | 05:34 PM
marky mark's Avatar
marky mark
Ok & thanks I'll have to do it later as I have to go to work soon.
Mark
Old Aug 7, 2004 | 02:29 AM
marky mark's Avatar
marky mark
[/IMG]
Old Aug 7, 2004 | 02:35 AM
marky mark's Avatar
marky mark
[IMG][/IMG]
Old Aug 7, 2004 | 02:39 AM
marky mark's Avatar
marky mark
Default here we go (I think)
[/IMG] [/IMG] [/IMG] [/IMG]
Old Aug 7, 2004 | 02:42 AM
marky mark's Avatar
marky mark
Default try it again
[/IMG]
Old Aug 7, 2004 | 02:44 AM
marky mark's Avatar
marky mark
Old Aug 7, 2004 | 02:45 AM
marky mark's Avatar
marky mark
http://img.photobucket.com/albums/v392/sennamick/Regulatortop.jpg
Old Aug 7, 2004 | 02:46 AM
marky mark's Avatar
marky mark
[/IMG]
Old Aug 7, 2004 | 02:48 AM
marky mark's Avatar
marky mark
[IMG]img.photobucket.com/albums/v392/sennamick/Passengerside.jpg[/IMG][/IMG]
marky mark's Avatar
marky mark
[IMG][/IMG]
Old Aug 7, 2004 | 02:49 AM
marky mark's Avatar
marky mark
[/IMG]
Old Aug 7, 2004 | 02:51 AM
marky mark's Avatar
marky mark
Old Aug 7, 2004 | 02:52 AM
marky mark's Avatar
marky mark
Old Aug 7, 2004 | 02:53 AM
marky mark's Avatar
marky mark
Old Aug 7, 2004 | 02:55 AM
marky mark's Avatar
marky mark
Default old dog learns new trick!!
It appears to be leaking from the top connector (blue) and not the hose as it appears. Seems to be running down onto the hose when motor is running.
To New Engine re-build pix need help posting please
Old Aug 7, 2004 | 03:00 AM
Pauld's Avatar
Pauld
nice looking job, was it a crate engine? or did you rebuild yourself?
Old Aug 7, 2004 | 03:10 AM
marky mark's Avatar
marky mark
Thanks Paul.
I thought seriously about a crate motor but in the end decided to have the 427 rebuilt.
I liked the modern look of the crate motor valve covers (thanks to Sallee Chevrolet for helping me find the correct parts to fit those small breather openings!) so that was my doing as was the new style K&N lid as well as the Jet Hot coated Hookers. Purists will not be impressed probably but I think it has a fresh look. It wouldn't take much to convert it to the stock look anyway (except for the fuel system changes).
Also, just a 270H Magnum Comp Cam. Just a bit conservative I suppose but didn't want to get too far away from steetable with a Muncie M-20 and 3:36 gears.
Dyno'd at flywheel : HP 456 @5,100 rpm, TRQ 536 @ 3,600 rpm. This with stock ovalports (L-36) and lowrise factory intake.
Car is a '69 Convert. I'll take a few car shots and post later.
Old Aug 7, 2004 | 03:35 AM
marky mark's Avatar
marky mark
Fouled plugs seem to be the culprit to the rough running engine. I'm switching to one heat range higher. From R43XLS to R44XLS.
