Replacing door parts
I need to replace my outside door handles, locks and while I'm there, I figured I replaced the window motors. I've gotten the inside panel off but am unsure how to proceed. I've got Chilton's and the Shop Manual but neither discuss the doors (72 vette).
Can someone point me to a good instructional spot? Or worse case, a reliable shop in the Raleigh NC area?
You need a service manual for the '72 and an assembly manual to show what goes where. If you haven't brought the motors yet. I would wait until you go thru the door channels. They get dry grease caked and the motors don't work well. If you clean them up and put litium white grease on them they usually work fine. If electrical is the problem , cleaning the contacts helps and then trouble shoot the wireing and the relays, etc. The window has to be taken off the channels and then they have to come out to get the motor and regulator out as a unit. Due to the spring on the regulator, you need to bolt it togetharto keep it from releasing before you remove the motor from it. This is all listed in the service manual.
PS; Just noticed you have shop manual, what kind? the service manual is red and yellow and covers all 1972 chevrolets.
My corvette library includes:
Corvette Shop manual 1966-82 (Covers all small-block and big-block corvettes)
Chilton General Motors 1963-82
How to restore & modify your Corvette
Motor's Auto Repair Manual 1972
Those are good. The service manual I have is like these
http://www.zip-products.com/Corvette...3E722121D82DF9
It has instructions or removing the window and channels.
It's just two nuts that hold the door handle on. I'm sure you'll drop the little clips 6 or 7 times while you're doing the project too Also a good time to adjust the handle to open sooner just play with it with the door panel off. if you screw with it too much & you have the door panel on you will have a hell of a time getting the door to open.
Here is a link of some projects I did, one is replacing the door regulator
http://www.corvetteclubcentralga.org...embersproj.htm
I have done the same except no power windows. There is not much room inside the well. One little trick is to use airplane glue to hold the small parts on the end of you finger while you align them or get them started. WD 40 works good with a brass brush to clear of the old grease.
