Any body else have any electrical gremlins?
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I've got a couple. I removed the dash to repair all the wiring. Everything was fixed, then I installed the dash. 20 minutes later the dash lights quit working. That's with a brand new headlight switch.
My other is I cleaned the ground on the fuel sending unit and the backup lights came on. Now they won't turn off.
No electrical gremlins for me because I have spent many hours exterminating them. Of course, all I do all day at work is track down those little suckers so I've gotten good at it over the years
Yeh, mee too Boofers.....course I hit mine in the head good a proper by rewiring the car to MY specs, eliminating about 1/2 the harness, meanwhile adding DPFI, which re arranged all the removed wires....;-)))
GENE
GENE
The worst one I ever had was my brake lights blowing the fuse. The parking lights worked fine. I would replace the fuse and then the brake lights would work fine. Then I would drive it around and notice that the fuse was blown again. I finally figured out that the rear wiring harness had fallen on the muffler and melted the insulation. If I hit a bump and the brakes it would short... Ended up having to replace the rear wiring harness...
Tim M.
Tim M.
