Rochester questions,
Gonna replace my Holley back to a Rochester 4MV.
1. As mine is an 1981, I assume it originally had an electric choke ?
Does this matter ? Can I use a manual choke, ? or no choke ( just pump the gas a few times )
2. AS for flow rates and bolt fittings, are all 1972 - 1982 carbs the same - therefore apart from the choke issue, can I use any ??
3. On a street driven car, is there much difference between vacuum and mechanical secondaries - performance wise ??
4. Typically on the street, what milage will a carb do before needing a rebuild ???
5, Any issues I have not covered above that I should know about ??
6. If anyone does have my " perfect carb " sitting home looking for a new place to live - shout !!
5, What is th CFM rating of the stock 4MV ??
I'd hook up one with an electric choke as it's only a wire to connect up. No choke isn't a problem for starting (just pump it as you say), but won't the fast idle be inhibited? ie. until the engine warms up it'll just keep stalling at idle (that's what mine was like when I disabled the choke).
If you're going with a Q-jet then it's definitely worth getting a book by Doug Roe on them. Excellent book with a lot of improvement mods.
