Bubble Tail lamps
Bubble Tail lamps
I have bubble tail lamps on the vert. They were on the vehicle when I
purchased it. When you turn on the lights, Are all four lamps supposed
to come on? If so, only two of mine come on.
1 Post
Which lamps are coming on...the 2 primary outside brake lamps..or the 2 inside lamps that have been piggy backed from the outside primary brake lights...or is just one side of the light lighting up..which ones are you having problems with? If the outside set of original lights are the ones working then check with a test light the piggyback connections from the outside primary light to the inside converted lights and go from there! Thanks Joe!
