Gas Gauge
Old Nov 1, 2004 | 05:30 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Gas Gauge
I need help with my gas gauge. When I put on the brakes the gauge goes to full when it is on empty. Also when I turn the turn signals on it pulses. Any help would be appriciated.
Old Nov 1, 2004 | 06:02 PM
Gordonm's Avatar
Gordonm
I would suspect a bad ground. Check the wiring on it first before doing anything major. There is a ground wire off the sending unit that I have seen go bad.
Old Nov 1, 2004 | 07:50 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i agree, start to find every ground connection in the back of your car and take them apart and sand/file the area and reassemble. any time funny electrical things happen you can suspect a ground issue. its more prevalent in our cars because the body is fiberglass.
Old Nov 1, 2004 | 09:49 PM
LiveandLetDrive's Avatar
LiveandLetDrive
My gas gauge currently "bounces" when it's not pegged full or empty (I often see both ) I suspect a bad ground but haven't gotten to it yet.
-Chris
To Gas Gauge
