Leaking header gaskets on my BBC!!...
Old Dec 13, 2004 | 10:55 PM
Doug Brandon's Avatar
Doug Brandon
Default Leaking header gaskets on my BBC!!...
I have tried two different sets, one the inexpensive Mr. Gasket style with the metal composite combo and the other the low end paper Fel-pro's. Both leaked badly on the left header on the top side of the #3 cylinder. I have new GM alum heads and reusing my old Hedman headers that have been recoated and never leaked before.
Will copper gaskets solve the problem (assuming I do not have a bent header flange-which I doubt). What about the "dead-soft" aluminum ones that Percy's has. Anyone use either type for street use? It is making so much racket I can bearly hear my solid lifters tapping away.
Old Dec 14, 2004 | 02:40 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Check the flange...it could have warped.
I have heard good results with the "dead soft" ones.
Old Dec 14, 2004 | 09:30 AM
MIKER's Avatar
MIKER
My Trick Flow heads have "D" shaped exhaust ports and my Headman headers have round port flanges. This presented a sealing challenge.
First time around I used square port gaskets made of copper, (SCE Pro from Summit Racing), and they leaked at the corners of the "D" port.
Second attempt was using standard el-cheapo exhaust manifold gaskets with high-temp gasket sealant and they held up fairly well but finally failed.
Third attempt was Mr. Gasket brand Ultra-Seal round port header gaskets and they too leaked at the corners of the "D" port.
Currently I'm using round port - Percy's dead soft aluminum gaskets, they sealed up fine and are holding.
Old Dec 14, 2004 | 10:05 AM
norvalwilhelm's Avatar
norvalwilhelm
I had problems so i removed the headers and cut with a hawksaw almost all the way through the flange from the backside between each port. I then used cheap gaskets, high temp copper silicon and never had a problem agian.
The cut allowed each tube to be pulled down better to the head. If there was warped problem the cuts releaved it.
Old Dec 14, 2004 | 10:27 AM
CGGorman's Avatar
CGGorman
I'm using the ones supplied with my Hookers and Stage 8 locking bolts with no leaks... The gaskets Hooker supplied were graphite coated on both sides and were some kind of perforated aluminum/paper sandwich about 1/8" thick. They compressed quite a bit while torqueing. They didn't have any name on them...
Old Dec 14, 2004 | 10:34 AM
zwede's Avatar
zwede
As has been mentioned: the shape of the port is important. I used round port gaskets and cut the corners back some with an exacto knife until the holes in the gaskets were the same shape as the ports in the headers.
I then used black RTV on both sides. Retorqued the bolts twice within the first few days. No leaks. I used the cheap mr gasket white ones.
Old Dec 14, 2004 | 10:37 AM
Brettmc's Avatar
Brettmc
Get some Earl's header seals. I had the same problem a few months back with the copper header gaskets and Earl's solved that. I also used their collector seals. This stuff is kinda pricey but you put em on and that's it. You DO NOT have to come back and retighten. Well worth it IMO.
Brett
Old Dec 14, 2004 | 11:02 AM
BB wowbagger's Avatar
BB wowbagger
I use Mr Gasket UltraSeal and they work great.Just remember that when you tighten the bolts,start with the ones in the middle and work your way outwards. Works for me
Old Dec 14, 2004 | 12:51 PM
an81shark's Avatar
an81shark
I've got percey dead soft alluminum and stage 8 bolts with zero leaks. its a small block tho
Old Dec 14, 2004 | 03:19 PM
theandies's Avatar
theandies
Brett
They are the best. Percy's are good too, I use them at my collectors. I also safety wire my bolts together.
Old Dec 14, 2004 | 03:24 PM
Fevre's Avatar
Fevre
Brett
If you are talking Earl's graphite ones they seal great.
Old Dec 14, 2004 | 08:50 PM
Doug Brandon
Thanks for the feedback. I ordered a set of Earl's and will see if that fixes the problem.
To Leaking header gaskets on my BBC!!...
