Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Reload this Page >
Is it normal for my Oil Pressure to drop to zero at idle?
Old 01-13-2005, 08:06 AM
BreauxBridgeKid
CF Senior Member
BreauxBridgeKid's Avatar
Default Is it normal for my Oil Pressure to drop to zero at idle?
At idle my oil pressure drops to almost zero, then goes up as i accelerate. While cruising maintains around 35 40. Is this right? I'm really not sure and dont know who to ask.
Thanks.
BreauxBridgeKid is offline
Old 01-13-2005, 08:26 AM
gerry72
CF Senior Member
No, that's not normal. As to the cause, it could be the gauge itself, the cam bearings, the rod or crank bearings, a worn pump, a stuck bypass...it's a long and troubling list. Assuming the gauge is reading true, your idle and 2k rpm oil pressure should be very close to the same. Your pressure readings with a cold and warm engine will vary a bit but a tight engine will be within 10psi. Broad ranges between idle and 2k rpm or cold and hot usually indicate worn cam bearings(this is where pressure is primarily built). If it really is a zero or nearly zero reading usually means that it can't build pressure so either the pump isn't spinning fast enough to account for wear in the pump or you have oil being dumped from a leak (bypass, galley plugs) before it can pressurize the galleys.
Hard to say but to me it sounds like your cam bearings are shot, but that's only my guess.
gerry72 is offline
Old 01-13-2005, 09:09 AM
Matt Gruber
CF Senior Member
replace the pump
Matt Gruber is offline
Old 01-13-2005, 09:20 AM
ram82fire
CF Senior Member
What he said
Geo
ram82fire is offline
Old 01-13-2005, 09:21 AM
Graemeinvette
CF Senior Member
Support Corvetteforum!
Graemeinvette's Avatar
!st things 1st. When was the last time you changed the oil and filter?
You need good oil in there with a clean good quality filter. If its still at zero on idle, try the pump, if its not that you are heading into rebuild territory, sorry!
Graemeinvette is offline
Old 01-13-2005, 09:26 AM
Paul Borowski
CF Senior Member
Paul Borowski's Avatar
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Before I'd make any call, I'd go to AutoZone or the like and get a simple oil pressure gauge. Disconnect yours, then temporarily install this new gauge then make a judgement call. Had a friend whose gauge quit working on one of his C3s. He thought he also had a "motor" problem. We disconnected his factory gauge, installed my remote $20 AutoZone gauge and saw that it was in fact his gauge on his car. His motor & oil pressure were fine. One thing I've learned about problems with C3s, seems like most of the time it's the "simple" problems that are most often overlooked.
Paul Borowski is offline
Old 01-13-2005, 09:30 AM
Steve's74
CF Senior Member
Steve's74's Avatar
yup!
Steve's74 is offline
Old 01-13-2005, 09:44 AM
68BLUEVETTE
CF Senior Member
68BLUEVETTE's Avatar
I havethe same problem, drops to ~10 - 15 psi at idle and up to 30 - 35 at speed.
68BLUEVETTE is offline
Old 01-13-2005, 09:55 AM
SharkAttack
CF Senior Member
SharkAttack's Avatar
It's normal for the factory gauge to vary with speed, but not that much. As mentioned above, check the gauge first. Remember these are old cars with technology that was cutting edge at the time they were designed and built.
SharkAttack is offline
Old 01-13-2005, 10:05 AM
den(thevetteman)78
CF Senior Member
den(thevetteman)78's Avatar
Got the same problem only when i drives it hard for a while and go from fast to a stop, the pressure go down and come back when i raise the rpm ,i asked a friend who work at GM dealer as a mecanic and it said it was normal. He said that the oil get so hot that it hard to build pressure. I don't know ,but it still scary . But it run like that now for a decade and no problem.
den(thevetteman)78 is offline
Old 01-13-2005, 08:18 PM
BreauxBridgeKid
CF Senior Member
Default I'm using 10w30
Should I be using something other than 10w30?
Old 01-13-2005, 08:31 PM
timbo79
CF Senior Member
timbo79's Avatar
These guages are old.. I relocated mine from the top tee on manifold to lower boss.. runs about 5lbs on average lower now..
Anyway,at idle and warm, it will drop a bit.. should rise as engine rpm rises... As i recall reading in one of Smokey Yanuck's build up books.. 10lbs pressure for every 1000 rpm... Just something I always have believed in...
0 pressure is BAD.. if it is not the guage..maybe cam. or crank.. I once had main bearings go and I lost pressure.. (ouch!)
Good Luck
timbo79 is offline
Old 01-13-2005, 08:47 PM
JoeRags
CF Senior Member
JoeRags's Avatar
With my brand spankin new 383, I was noticing the same thing. The needle on my '70 would drop nearly to zero. I called my builder, he actually was with me when we fired it the first time, and he told me that it is ok. The gauge is in 15 psi incriments, and from what he told me, it is perfectly normal for small block GM engines to run around 7 psi at idle speed. Thats half way to the first line on the gauge. As soon as you touch the gas, it jumps right up. Oh yea, I'm running 10w30.
Joe
JoeRags is offline
Old 01-13-2005, 09:08 PM
joe73vette
CF Senior Member
joe73vette's Avatar
I picked up 5 psi by switching to single viscosity SAE30 oil. No need for the 10W in a summer car. Joe
joe73vette is offline
Old 01-13-2005, 11:19 PM
den(thevetteman)78
CF Senior Member
Nice 68 Firebird ,if i can afford a second dream car it would be a 67 or 68 , i found they do look a lot better than the 69 with the pontiac lemans frond end.
Old 01-14-2005, 12:26 AM
glen242
CF Senior Member
Joe
I have a 29 year old motor, including oil pump, and if the oil pressure was nearly zero at idle, I would be very concerned. My GM 'vette spec form says "normal oil pressure is 32-40 psi @ 2000 rpm". I was, at one point, concerned about high oil pressure. Bought an aftermarket mechanical gauge and found the stock electric gauge was off by a lot. At the least, I would spend the +/- $15 and try an aftermarket gauge to verify your readings. At idle I have about 40# with hot oil and it does not rise much with RPM.
Did your "builder" tell you what the bearing clearances were on the engine? I have to believe they were very loose, compared to stock, to have that kind of pressure.
glen242 is offline
Old 01-14-2005, 08:52 AM
Matt Gruber
CF Senior Member
i've found 20w50 is worth 11psi over 10w30.
29 went to 40 @65mph
Old 01-14-2005, 10:54 AM
mvftw
CF Senior Member
mvftw's Avatar
Same problem here If the idle went below 700 (normally at 900 it is a 20*) it will go to zero. Even with a mechanical gauge. I replaced the the pump with a Melling 55A (high pressure, stock volume). Now my cold pressure is 70+ but it still goes to zero went hot and idle goes low. I think it's bearings. I use 20w-50. I'm going to let it go till I here knocking. Motor still runs strong.
mvftw is offline
Old 01-14-2005, 11:15 AM
Gage
CF Senior Member
Same issue with mine. Replaced gauge, even hooked up mech gauge from autozone to verify. They all read about 0 at idle with hot engine. Picks up to about 25 psi while cruising. Has been that way for over a year, no knocking noises, no problems, runs great. I have to think if it was a bad thing that something would have broke by now after 3K miles runnning like this....
Gage is offline
Old 01-14-2005, 11:27 AM
Aflac
CF Senior Member
Aflac's Avatar
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Never over look the obvious! Always start at the easiest and simplest thing possible. Will save you a lot of headaches and money in the long run!
Aflac is offline
Quick Reply: Is it normal for my Oil Pressure to drop to zero at idle?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
