FS: 1973 Corvette Frame off nut & bolt restoration # matching
Hello all. i know i am a new member. i was told about this forum by another corvette owner that is on the forum. i read through the rules and it did not appear that i am in violation of any rule. I do have the title with me it is clean
1973 Chevy Corvette
VIN- 1Z37J3S414975
Odometer- 87206 (3612 miles since restoration)
Horsepower- 400-425
Numbers matching- Yes
Price - $39,000
Title in hand with no lien
Location- Edwardsburg, Michigan.
Complete frame off, nut and bolt restoration completed in 2010 . I have $75,000 into the car and restoration(i have all the reciepts as well if proof is needed).This car is absolutely gorgeous. It is a numbers matching car. i have only put 3612 miles on the car since the restoration was completed. car is stored in a climate controlled garage year round. I am planning on another restoration project so i need to make room. this car has to go.
I chose to paint the car with the Baldwin Motion Stripe. I have always loved the look of that stripe. The car was appraised at $60,000+ a few years ago. i know the c3 market has gotten soft so my price i feel is spot on.
The Restoration took place at Mann's Corvette in Mishawaka Indiana.
Car Factory Options
Power Steering
Power Brakes
Power Windows
Rear Defrost
Tilt/Tele steering
Map Light
No rear Luggage Rack
No A/C
________________________________________ ________________________________________ __
Engine- 93 Octane
Original L48 350 numbers matching block (original heads and intake/carb come with purchase)
350 bored .030 10:1 Compression ratio 400HP
aluminun heads 2.02/1.60 valves 64cc chambers
Erson cam 5.48 548 lift 226/234 duration .050 rollercam with roller tip rockers
aluminum holley stealth intake dual plane
holley 770 street avenger carb
holley big end fuel pump 80gph vaccum secondaries seamless secondary activation
full msd ignition MSD 6al box, MSD billet tach drive distributor, msd blaster 2 coil, msd wires, accel race plugs, new ignition shielding
High Pressure High Volume oil pump 70 psi
Hedman long tube headers into aluminumnized 2.5" exhaust with Hpipe
Original radiator Recored with sealed fan shroud
Transmission
4 speed M20 Transmission
South bend Clutch and Pressure plate
Rebuilt rear end with 3:36 gear LSD
Original Driveshaft
New Shifter and linkage
Interior Trim code 418
Corvette Central complete saddle interior.
Seats frames sanded and painted.
Seats have new foam
Corvette Central Door panels, controls, and trim
Rebuilt OEM speedo and tach
Corvette Central Seat belts with Original GM Buckles
Corvette Central Carpet and trim
new center console, new parking , new rear 1/4, a pillars and misc trim pieces
New gauges in center console
Custom padded armrest in matching saddle that is easily removed
Corvette Central Digital OE radio with RCA's.
Alpine Type R 6x9's in interior matching box (easily removeable)
Original steering wheel with new emblem
New heater core
Chassis
Brand new powdercoated OE chassis from Vetteproducts
Brand new fuel tank with stainless Lines
Complete rewire with new harness
New Body mount kit
New metal rear spring
New stock front suspension
New Stainless sleeved calipers
New Stainless brake lines
New new rubber bushings through the whole suspension
new upper lower control arms
new inner/outer tie rods
new idler arm
New master cylinder and brake booster
New radiator support
rebuilt power steering
rebuilt slave cylinder
Rebuilt steering box
Body work
Exterior Color code 980 Orange
All body work done with excellent quality. no cracking whats so ever
Base clear BASF paint 3 coats clear, wetsanded, buff/polish
Car was painted original Orange. added the Baldwin motion black stripe to the car. also have 1 quart left of the original mix of orange to go with car
Restructured/reinforced birdcage better than stock
perfect gaps all the way around the car
fiberglass front bumber fitted to car prior to paint
rear bumpers fitted to car prior to paint
New Tops fitted to car
All new seals and weatherstripping through whole car
New Door strikers
All Stainless trim professionally polished
Halogen Lights
Corvette central lights, markers, and emblems
Original glass door, new rear window (correct date code) aftermarket windshield
Original wheels powdercoated, original center caps restored, Corvette central beauty rings.
new headlight vaccuum line kit
flaws
one chip headlight bezel in pictures
hood strip paint bleed small in picture
small stone scratch on driver side lower trim in pictures
Original center dash trim not perfectly aligned
Ebrake console seems a few spots of the dye has lifted but is hidden by armrest pad if you use it.
Pictures of the car. The flaws are the last pictures listed.
1973 Chevy Corvette
VIN- 1Z37J3S414975
Horsepower- 400-425
Price - $39,000
Car Factory Options
Power Steering
Power Brakes
Power Windows
Rear Defrost
Tilt/Tele steering
Map Light
No A/C
Engine- 93 Octane
Transmission
Original Driveshaft
Seats have new foam
New heater core
Chassis
New Body mount kit
new idler arm
Body work
New Door strikers
Halogen Lights
flaws
73 resto
Boy what a great looking vette. allot of money but man what a nice job. Question, whats the holley carb and manifold on your work bench. Is it for sale?
Those are the ones that came with the car when i purchased the car 16 years ago. manifold, heads are number matching so they will be staying. i may have a few manifolds and carbs for sale i will pm you.
