Door Panels
Old Apr 25, 2005 | 09:25 AM
HOOBS's Avatar
HOOBS
Default Door Panels
My 96 vette's door panels are loose...They were like this when I bought the car.....does anyone have any tips for (SNAPPING) them back into place? Any secrets to it?
Old Apr 25, 2005 | 10:58 AM
Steel Blue 91's Avatar
Steel Blue 91
If you are talking about the top of the door panel being "floppy" when you close it, this tech tip might help you. I did it a few years ago on my 91 and it's held up fine.
https://www.corvetteforum.com/techti...=242&TopicID=2
Old Apr 25, 2005 | 01:37 PM
GSjimbo's Avatar
GSjimbo
If the panel is loose at the bottom, the plastic "push in" buttons might be worn out from previous removal. Stand by, GM charges about $5.00 each for them!
If the panel is loose elsewhere you might have a screw loose (no pun intended) or it might not be hung correctly.
To Door Panels
